DOSBOX with 32 bit code
First post, by zeras
Hello,
i habe tested dosbox with an emulation of a machine control. This works fine so far.
Now we have a newer control with 32 bit code, which uses mostly same software interrupts. Does dosbox support 32 bit code as well or is this restricted to 16 bit code?
Any answer would help.
zeras
