Reply 20 of 24, by The Serpent Rider
A potential workaround would be to backup the FAT32 filesystem, plug into a modern system, format as NTFS, manually TRIM
That's redundant. Formatting will automatically trigger TRIM in modern OS.
Reply 21 of 24, by imi
if you don't use the machine every day and use a SSD with good internal garbage collection you really don't "need" TRIM, sure it helps, but your SSD will work fine without it.
Reply 22 of 24, by darry
The Serpent Rider wrote on 2021-02-04, 03:12:
Thank you for that info . Could you please be more specific about what constitutes a modern OS in this context (other than Windows 10, obviously), in regards to both Windows and, if possible MacOS and Linux ?
IMHO, though it may be redundant, it would definitely not the be longest part of the process if you decided to do it any way (a few mouse clicks and seconds worth of waiting) .
Reply 23 of 24, by douglar
You can get a Pata or Sata ssd to release all allocated blocks jn Dos by doing an AT secure erase command. I tried it out, but I’m worried that it screwed up the flash wear leveling. There were some warnings I should have paid more attention to when I ranit. I need to test it out some more.
Reply 24 of 24, by The Serpent Rider
Windows 7+, Ubuntu 14.04+ based builds.
