Nexgen - the 486 killer - WIP
Reply 60 of 69, by amadeus777999
Beautiful system with some very nice components!
Timing Doom Shareware's demo 3 would be nice.
Reply 61 of 69, by Intel486dx33
Can you posts some benchmarks.
I would like to compare it to my 486 and 5x86 computers.
Speedsys
Topbench
Drystone
Graphics benchmarks too.
Thanks.
Reply 62 of 69, by mpe
Intel486dx33 wrote on 2021-02-07, 11:55:
Can you posts some benchmarks. I would like to compare it to my 486 and 5x86 computers. […]
Speedsys
Topbench
Drystone
Thanks.
See here - https://dependency-injection.com/the-perfect-pentium/
Blog|NexGen 586|S4
Reply 63 of 69, by Intel486dx33
mpe wrote on 2021-02-07, 12:16:
Speedsys
Topbench
Drystone
Thanks.
Yeah, but I want to compare with his specific build since he calls it a “486 killer”.
I think the only CPU that killed off the 486 was the Pentium.
Reply 64 of 69, by mpe
yes those were captured on this system
It was just a hyperbole. In reality the performance of NexGen P90 is sometimes inferior even to 486DX4-100 in some benchmarks. Especially graphics tests in DOS.
See also http://retronn.de/imports/nexgen_nx586.html
Blog|NexGen 586|S4
Reply 65 of 69, by elianda
Nice NexGen System.
Where did you connect the Sanyo CDR-H94RSA SCSI CD-ROM drive?
I don't see a SCSI controller card in your system pictures. Do you use some kind of SCSI <-> IDE converter on the Promise Controller?
What is your experience with other graphics cards in this system?
With my ET4000W32/i VLB from Gainward I had to use an additional WS to make it work, so in the end the S3 Vision 864 ended up there as graphics card.
Youtube Channel
Reply 66 of 69, by Storm82
Huh he has a Adaptec VL SCSI Controller in there at the top of the picture 😀
Reply 67 of 69, by elianda
Ah man, sorry skip that question, I somehow missed that page of the thread.
Youtube Channel
Reply 68 of 69, by Grzyb
mpe wrote on 2019-12-07, 18:16:
First the NIC. HP J2573 with support for 10mb ethernet as well as 100VG AnyLAN standard (which I would like to use for my home retro LAN).
Have you tried that NIC with mTCP?
I'm trying it with Pentium MMX 166, using the 10 Mbps connector.
In Windows 95 OSR2, it works OK - FTP download to NUL is about 800 KB/s.
With mTCP, however, it sucks real bad, with both the Crynwr packet driver and ODI+ODIPKT:
default settings - 106 KB/s
MTU 1500 - usually less than 10 KB/s, often so slow it's hard to even measure
Nie rzucim ziemi, skąd nasz root!
Reply 69 of 69, by matze79
mpe wrote on 2019-10-04, 22:04:
The Nx586-P90 is the most common NexGen CPU model. Clearly better than almost any 486, but not quite at Pentium level. But no FPU 😲 And again the only option for me.
Software compatibility is much more worse then 486.
Basicly a 386 on Steroids.
Nice Build!
