Different Versions of Ensoniq AudioPCI
First post, by th1r5bvn23
Recently I'm digging into various AudioPCI cards but realize that the drivers for different models of them are different. The drivers on vogonsdrivers.com are all for ES1371/ES1373 but no ES1370 or EV1938. So I downloaded many drivers for different operating systems and looked for device IDs and here's what I've found:
ES1370/CT5507: VEN 1274 DEV 5000
ES1371/CT2518/ES1373: VEN 1274 DEV 1371
CT5880: VEN 1274 DEV 5880
EV1938: VEN 1102 DEV 8938
CT5880's driver always comes with newer version ones of ES1371/CT2518/ES1373, which doesn't include DOS driver. Besides, I've read from some website that CT5880 is an updated version of ES1371/CT2518, which added 5.1-channel output. Then I found cards as many as possible to look for their chips:
AudioPCI 1000/3000/SoundBlaster PCI 64: ES1370 with AKM AK4531
AudioPCI 5000: ES1371 with TriTech 28023
AudioPCI 5100: ES1371 with TriTech 28023 and LM1876T amplifier
AudioPCI 5200: ES1373 with TriTech 28023
CT4700 (SoundBlaster PCI 128): CT5507 with AKM AK4531 and TDA7360 amplifier
CT4730 (SoundBlaster PCI 64V): EV1938
CT4740 (SoundBlaster PCI 16): ES1373/CT5880 with Crystal CS4297A/SigmaTel STAC9721T and TDA1517P amplifier
CT4750 (SoundBlaster PCI 128 Digital): CT5880 with SigmaTel STAC9708T (The only 5.1-channel AudioPCI)
CT4810 (SoundBlaster Vibra 128): CT2518/CT5880 with Crystal CS4297A/SigmaTel STAC9721T and maybe TDA1517P amplifier
CT5800: ES1373 with SigmaTel STAC9721T
Also there're some mysterious EMU10K1X (VEN 1102 DEV 0006) cards, like Sound Blaster Live! SB0200, Sound Blaster 5.1 SB0680 and Ectiva Audio 5.1 TP0033, which according to some posts may be AudioPCI, though I'm suspicious about this.
Because of the use of SigmaTel STAC9708T codec, the CT4750 card should have the best output quality.
Drivers for these chips are different. Except EMU10K1X, there are 3 different drivers for these chips. ES1370/CT5507 one, ES1371/CT2518/ES1373/CT5880 one, and EV1938 one. Drivers on Ensoniq website are for ES1370/CT5507 only and there's no DOS driver. Drivers on Creative website are for ES1370/ES1371. No EV1938 driver anywhere. I'm sure that CT4730 was a retail card. Some DOS drivers mislabeled ES1371 as SoundBlaster PCI 64V, but in fact it's not.
Therefore I'm interested about driver support for these cards under DOS/Windows 9x/Windows XP. It would be greatly appreciated if someone can provide drivers for these cards for DOS. Currently only ES1371/ES1373/CT5880 have DOS drivers.
Edit: drivers here Re: Different Versions of Ensoniq AudioPCI
AMD K6-2+ 500, FIC PA-2013 2.0 (1MB cache), 128MB SDRAM PC100, Voodoo3 3000 AGP, Labway Yamaha YMF719B-S with NEC XR385
AMD Athlon 64 3000+, ECS K8M800-M3, 512MB DDR 400, GeForce FX 5200, SoundBlaster Live! SB0060
Reply 1 of 29, by yawetaG
Tidbit of information about the AudioPCI 5000:
This is a OEM version that was used by Gateway 2000, amongst others. It has better AD/DA conversion than the standard models (see old Ensoniq website on Internet Archive.).
Also, I see you have it listed as using a ES1371 chip, but mine uses the ES1370 chip.
Reply 2 of 29, by th1r5bvn23
There are too many different OEM versions, most of which I can't find on the Internet. So, I'm only covering retail cards or some common OEM ones in this thread.
Reply 3 of 29, by th1r5bvn23
By the way, I've also found that VMware had x64 driver for ES1371 (VMware VMaudio), which I tested working in Windows 10 x64 (in VMware).
Reply 4 of 29, by zyga64
th1r5bvn23 wrote on 2020-02-23, 02:31:
Nope. There are drivers for ES1370 too. See this link: Re: Ensoniq AudioPCI / ES1370 DOS Emulation not working
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 5 of 29, by th1r5bvn23
After some time collecting various drivers, I've figured out the driver compatibility of different versions of AudioPCI.
However, I don't know whether Ensoniq ES1371 DOS drivers can be used with CT5880 cards (like CT4750). I hope someone can test it.
Here are drivers for these cards:
1) ES1370/CT5507, VEN_1274&DEV_5000
DOS drivers from Ensoniq (Soundscape compatible): https://web.archive.org/web/20010417011500if_ … ds/apiwiz31.exe
Vista/7 x86 drivers from Microsoft: http://download.windowsupdate.com/msdownload/ … 574c94c3902.cab
2) ES1371/ES1373/CT2518, VEN_1274&DEV_1371
DOS drivers from Ensoniq (Soundscape compatible): http://www.vogonsdrivers.com/files/ensoniq_do … or_audiopci.zip
DOS drivers from Creative (SB16 compatible): http://www.vogonsdrivers.com/files/audiopci.zip
Vista/7 x86 drivers from Microsoft: use the same package as ES1370/CT5507
VMaudio x64 drivers from VMware: can be stripped out from latest version of VMware Tools
3) CT5880, VEN_1274&DEV_5880
DOS drivers from Creative (SB16 compatible): use the same package as ES1371/ES1373/CT2518
Vista/7 x86 drivers from Microsoft: use the same packge as ES1370/CT5507
4) EV1938, VEN_1102&DEV_8938
DOS drivers from Creative (SB16 compatible): http://www.vogonsdrivers.com/files/sbpci.7z (\Audio\English\EctDos\data1.cab, extract with Universal Extractor or isunpack)
Also all drivers above plus VXD/WDM driver (collected and reorganized by me):
https://mega.nz/#!JLZinQQb!uvp5gmKcJ_k7Ssa_uq … -9R5WYouzk-7a60
Reply 6 of 29, by Ozzuneoj
yawetaG wrote on 2020-02-23, 10:17:
I was curious, so I looked it up:
https://web.archive.org/web/19980118113345/ht … /apci_s5016.htm
vs
https://web.archive.org/web/19971224042528/ht … com/a_specs.htm
Reply 7 of 29, by th1r5bvn23
Update: VMware VMaudio driver won't work with real hardware. It's intended for use within VMware only.
Reply 8 of 29, by Horun
DOS drivers from Ensoniq (Soundscape compatible): http://www.vogonsdrivers.com/files/ensoniq_do … or_audiopci.zip >> http://www.vogonsdrivers.com/getfile.php?fileid=373
DOS drivers from Creative (SB16 compatible): http://www.vogonsdrivers.com/files/audiopci.zip >> http://www.vogonsdrivers.com/getfile.php?fileid=374
DOS drivers from Creative (SB16 compatible): http://www.vogonsdrivers.com/files/sbpci.7z >> http://vogonsdrivers.com/getfile.php?fileid=370
End
Sorry to bring up a nearly one year old topic but discovered some links to Vogons library were wrong (you cannot link direct to the file, only the page)
Reply 9 of 29, by Shreddoc
This is pretty niche, but since this thread's a repository of all things AudioPCI, then it might as well be here.
A year or two back I picked up an AudioPCI 3000 but unusually, it came with a separate "power amplifier" board based around the LM1876TF.
Excuse the crappy better-than-nothing phone photos on a stormy day:
Note in these photos that the heat sink for the aforementioned IC has been removed by me, in the course of mucking around with it.
Reply 10 of 29, by Horun
Shreddoc wrote on 2021-01-16, 23:10:
This is pretty niche, but since this thread's a repository of all things AudioPCI, then it might as well be here. […]
Interesting ! Assume the back plate was bolted to the holes with square solder pads or maybe mounted somewhere else in a specific OEM case ?
Reply 11 of 29, by happycube
IIRC the best versions were the ES1370's with Tantalum caps, basically before Creative got their grubby cost-reducing hands all over them.
Reply 12 of 29, by Wanderer
Recently I'm digging into various AudioPCI cards but realize that the drivers for different models of them are different. The dr […]
Hello,
there are two more models to add to the list:
CT5803 (Sound Blaster PCI 128): ES1373 with Crystal CS4297A, SPDIF output
CT5808 (Sound Blaster PCI 128 Compact): CT5880 with Creative CT1297, low-profile card (no Gameport), SPDIF output
Reply 13 of 29, by Shreddoc
Horun wrote on 2021-01-17, 05:45:
Yes you're correct the Ensoniq power amp module did originally come on a standard backplate.
I messed with it a bit to see if I could use it as a cheapfree-and-cheerful mini desktop amp buut it wasn't really worth the hassle. The high water mark of "90s power amplification made for PC internals" being-what-it-is.
Indeed an interesting/weird little thing, but very little practical purpose! This right here, is it's 15 seconds of fame and glory. 😀
Reply 14 of 29, by rejean
Hello all,
I just acquired an old PC tower with an Ensoniq AudioPCI 3000 card using the chip ES1370, my OS is Windows NT 4.01 and I am unable to find the drivers for that card!
By any chance, is there someone here who have the drivers for NT available?
Thank you so much for your help,
Rejean
Reply 15 of 29, by Kamerat
rejean wrote on 2021-02-01, 15:27:
You can try out this driver specified by Creative as "SB PCI64 (ES1370 card)". Wavesets not included.
YouTube channel
Reply 16 of 29, by Rawit
Does the Ensoniq 1370 with Ensoniq drivers offer an option for Ensoniq Soundscape only under DOS? So no Sound Blaster including FM? I've seen attempts to disable only the FM, but can the Sound Blaster inc. FM be disabled all together?
And the 1370 is incompatible with the Creative drivers? Vendor ID check?
YouTube
Reply 17 of 29, by Kamerat
Rawit wrote on 2021-02-08, 08:38:
It emulates FM and Sound Blaster Pro too, not sure about disabeling the FM synth. Don't think Creative ever made DOS drivers for the ES1370. Got a couple of recordings from the ES1370 here.
YouTube channel
Reply 18 of 29, by yawetaG
If you run your DOS programs from within Windows 95 or 98 Ensoniq Soundscape mode will work in games.
Reply 19 of 29, by Rawit
It's for a DOS/Windows 3.11 machine. I found the drivers but no documentation. As I plan to do SB in hardware I thought it would be fun to add Ensoniq support as long it doesn't conflict with other hardware or hijacks the Adlib port for that horrible FM it does.
YouTube
