PowerPC Dynamic Recompiler (patch)
Reply 120 of 137, by retro100
Hi! Dosbox for Wii with jmarsh great patches is available.
@jmarsh
Thank you very much for the great Dynamic Compiler patches!
@Stretch
A forked dosbox-wii version with the Dynamic Compiler patches from jmarsh is now available for the Wii (and WiiU).
I have synced the dosbox-wii to SVN r4301 and applied the patches from jmarsh for Dynamic Compiler support. Unfortunately, there is a bug at the Wii version (independent of the patches. The patches works great!). The bug is that the virtual keyboard cannot be used. A real keyboard is no problem.
For more informations see https://github.com/dborth/dosbox-wii/pull/57 and https://github.com/retro100/dosbox-wii.
I also made some benchmarks with PCPBench. With core=dynamic I get a result of 2.9 fps on my Wii and with core=normal the result is 0.5 fps. For the benchmark results see https://github.com/retro100/dosbox-wii/blob/m … rk_Wii_WiiU.txt. A pre-release is also available at https://github.com/retro100/dosbox-wii/releases.
Currently I applied the patches ppc_dynrec.diff and drive_fat_BE.diff from jmarsh. Have I forgotten any patches or are there any other patches that should be added to the Wii port?
Best regards
retro100
Reply 122 of 137, by retro100
@Dominus: With dynamic enabled I get 2.9 fps. With disabled dynrec (core=normal) I get 0.5 fps. This is a factor 5.8.
Wenn I use Dos/32A instead of DOS4GW at PCPBench the results are 3.1 fps vs 0.7 fps. This is a factor 4.4.
PCPBench 1.03c on Wii
---------o---------------------------------------o-------------------o
version: | Dosbox WII r4301 with dynrec | Dosbox WII 1.7 |
| master branch | |
---------o---------o---------o---------o---------o---------o---------o
core: | dynamic | dynamic | normal | normal | normal | normal |
cylces: | max | max | max | max | max | max |
extender:| Dos/32A | DOS4GW | Dos/32A | DOS4GW | Dos/32A | DOS4GW |
result 1:| 3.0 fps | 2.8 fps | 0.7 fps | 0.3 fps | 0.3 fps | 0.2 fps |
result 2:| 3.1 fps | 2.9 fps | 0.8 fps | 0.5 fps | 0.2 fps | 0.3 fps |
result 3:| 3.1 fps | 2.8 fps | 0.6 fps | 0.5 fps | 0.3 fps | 0.2 fps |
For all results see https://github.com/retro100/dosbox-wii/blob/m … rk_Wii_WiiU.txt
Reply 124 of 137, by jmarsh
I highly recommend you solve the issues with using devkitpro's SDL, it is much faster than dborth's version.
Reply 125 of 137, by retro100
jmarsh wrote on 2021-02-09, 20:16:
Thanks for the tip! I hope to have time to solve the issues soon 😀 And thanks again for the patches!
Reply 126 of 137, by Stretch
I got a score of 95388 parrots, 35.4 XT in speedtst with core=dynamic, cycles=max, cputype=486_slow
I will try Jazz Jackrabbit on the wii later and report the performance.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 127 of 137, by Stretch
Played the first level of Jazz Jackrabbit. It was very playable on low quality, no animation. Dosbox set with core=dynamic, cycles=max 90%, cputype=auto, with GUS at 22khz. Some occasional minor slowdown but not enough to ruin the experience.
The game will crash with an unhandled exception at startup if you don't have the wiimote pointing at the wii sensor bar.
Reply 128 of 137, by digger
Nice work. 🙂
Would this also be useful when building DOSBox for POWER9 (ppc64le) architectures, such as the Talos II workstation or the Blackbird motherboard?
Or would the different endianness and the fact that it's a 64-bit architecture make it practically a rewrite?
I believe that POWER9 CPUs can run in both little-endian and big-endian modes, if that helps.
Perhaps it would work if DOSBox on POWER9 were to be spun up inside a paravirtualized 32-bit big-endian VM instance?
Reply 129 of 137, by jmarsh
You wrote the same thing at the beginning of this thread.
If you look around pages 3 or 4 you'll find discussion about porting to ppc64le.
Reply 130 of 137, by digger
Oh wow, that's embarrassing. I've been following so many threads both here and on GitHub, I got confused. Sorry about that. 😅
Reply 131 of 137, by azn
retro100 wrote on 2021-02-09, 16:55:
@Dominus: With dynamic enabled I get 2.9 fps. With disabled dynrec (core=normal) I get 0.5 fps. This is a factor 5.8. Wenn I use […]
| master branch | |
Hello retro100, as it is really hard to get your contact information I am glad you are here. I would like to contact you as you are the one releasing the most up to date version available for the wii. Maybe you saw here on vogons I was looking for a way to be able to switch the mapper on the go while dosbox is running. After googling for quite a while i found a different project that has it done and I got into the piece of code that does the job. Yet i am unable to produce a patch myself for the Wii version. Would like to hear from you, contact me on azn#7863 / Discord if you can. Or send me an e-mail - it is accessible from my web log(url on my vogons profile page). If you can implement this code into the wii version it would be really great news 😉
Take a look at my YouTube channel - totally dedicated to retro shooters
Reply 132 of 137, by retro100
azn wrote on 2021-03-15, 20:31:
Hi azn!
I now have enabled "Issues" on my dosbox wii fork https://github.com/retro100/dosbox-wii
Please post on github as Issue your suggestion. I think this thread has the wrong topic for your intention 😁 Maybe you can also write some infos into the issue about were I can find the code for the "switch mapper" (if the code is public available).
Reply 133 of 137, by azn
retro100 wrote on 2021-03-17, 23:09:
Hi azn! I now have enabled "Issues" on my dosbox wii fork https://github.com/retro100/dosbox-wii Please post on github as Issue […]
Hi azn!
Thanks for your answer, I would do for sure, as it is at first cool feature, and the only thing that keeps me from turning my wii into nice dosbox gaming console 😉
Reply 134 of 137, by vorob
Hi! Sorry for silly questions, I’m total noob in programming stuff, I was wondering how dosbox would run on my power pc iBook g4 with 1.33 cpu. At first I’ve downloaded latest official release, tried duke nukem 3d and it was bad. Then I found this thread and special dosbox version with patch applied sadly there was no change.
(https://sourceforge.net/projects/dosbox-ppcjit/)
That’s how game runs in 320x200: https://www.youtube.com/watch?v=kgWM03LEyOE
I wonder if I’m doing smth wrong, maybe there is a chance for better performance?
I already had a thread about this subject, but this time I found the author of this patch. Can’t be a better place to ask about my situation 😀
Reply 136 of 137, by jmarsh
Reduce the display size using the in-game settings, test different frameskip settings... Duke3D didn't run well on 486s, which is basically what you're emulating with a machine like that.
Reply 137 of 137, by mr_space
1992/93 seems to be the limit on my 2004 eMac. I use source ports found on the Garden for Duke3d, SW, Doom, Quake etc... I mostly play Frontier and Epic Pinball so I'm OK.
