Feel the RAGE!
First post, by Chadti99
Testing an original ATI 3D Rage I.
Reply 1 of 7, by douglar
Is it a 3D Xpression, part number 109-34000-10 ?
Reply 2 of 7, by Chadti99
It's onboard an IBM Aptiva 2159 S76 but yes I think it's the same or similar chip. The onboard chip only mentioned it being a Mach64 so it was before the Rage rebranding. You get this splash screen when firing up the ATI Rage version of Wipeout.
Check here to help identify which version of Rage you have or looking to get.
https://en.wikipedia.org/wiki/ATI_Rage_series
Reply 3 of 7, by douglar
I was putting together this list to help people too--
https://www.vogonswiki.com/index.php/ATI#ATI_ … e_add-in_boards
The Mach64-GT chips are not very common. Looks like you have one.
https://www-01.ibm.com/common/ssi/ShowDoc.wss … quest_locale=en
Video memory (2) 40 pin SOJ DRAM, 256KB x 16, 60NS, EDO
SVGA Chip set ATI 264GT "Rage"
Video Monitor VGA or SVGA (Operations at VGA or higher compatibility frequencies)
Physical interface compatible with IBM's PS/2 VGA Interface
Video Modes Dependent on system video memory:
1MB-VGA (Text and graphics modes)
640 x 480 (256, 64K or 16M colours)
800 x 600 (256 or 64K colours)
1024 x 768 (256 colours)
2MB-VGA (Text and graphics modes)
800 x 600 (256, 64K or 16M colours)
1024 x 768 (256 or 64K colours)
1280 x 1024 (256 colours)
Reply 4 of 7, by Chadti99
Fantastic info, thanks for this! I’ve got a Rage 2 and Rage Pro on the way as well!
Reply 6 of 7, by dr.zeissler
need some testing-software/demos for my Onboard-RageIIC 😀
Reply 7 of 7, by Chadti99
The post animation is very cool!
