Hi F1etch,
My 5.38.2582-3dcif files are also here (upload.ee uploaded files expire after some time).
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … ge-MarxVeix?w=1
Thank you Takedasun!, seems that you have uploaded my other and earlier 4.11.2582 / 4.11.2611 builds also there with my win9x opengl package (ragepro-opengl.zip) that is not latest by now, but still has many OpenGL ICD for Rage cards.
My other earlier builds and tryouts:
w82582en.zip
4.11.2611_rage-3dcif.zip
MACXW4_4.11.2582_Fast_B_est_now_XL_Beta.zip
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … e%20PRO_CIF?w=1
Win9x Rage OpenGL files (not my latest and not complete, still we miss many).
https://disk.yandex.ru/d/eV600jDAliJ_3w/OGL_RagePro?w=1
ATi RagePro OpenGL files
NB! For the 2573/2582 and probably some other, older drivers:
MACXDD16.DL_ (.DLL) can be latest 5043 or older with other/older versions of MACXDD32.DL_ (.DLL)
RAGE2C - latest working MACXDD32.DL_ (.DLL) is 5033 or older and ATI3DCIF.DL_ (.DLL) can be latest 2696 or older
RAGEPRO (MACXDD32.DL_ (.DLL) can be latest 5035 or older and ATI3DCIF.DL_ (.DLL) can be latest 2696 or older
RAGEXL working (MACXDD32.DL_ (.DLL) is 5029 and working ATI3DCIF.DL_ (.DLL) is 2692
Rage2C, RagePro, RageXL all work with MACXDD16.DL_ (.DLL) 5043 or older, (MACXDD32.DL_ (.DLL) 5029 and ATI3DCIF.DL_ (DLL) 2692
Rage2C 3D-Demo might not always work correctly and Knight demo is only for RagePro/LTPro/XL, but games are working for ATi Rage2C
Maybe there exist even newer MACXDD16.DL_ (.DLL) , but more important is ATI3DCIF.DL_(.DLL) and MACXDD32.DL_ (.DLL) file versions.
MACXDD16.DL_ (.DLL) 5043 (renamed atid16ad.dll) , (MACXDD32.DL_ (.DLL) 5029, ATI3DCIF.DL_ (DLL) 2692 are used in 5.38.2582-3dcif
Original sp10912.exe has 5035 and w9x_rpro_5386b6a.zip has 5034 version of MACXDD32.DL_ (.DLL), so it makes Rage2C 3DCiF Freeze, like Gona has tested those and other Rage drivers, downgrade to 5033 or older and it will work there as well with Rage2C, but best to use is (MACXDD32.DL_ (.DLL) 5029 and ATI3DCIF.DL_ (DLL) 2692 ones, at least in latest MACXW4 drivers.
My 4.11.2611 3dcif driver i also update some day, maybe soon, but for Rage XL use 5.38.2582-3dcif.
If my driver also does not work, then send your vendor and device id info from that Rage XL, like here:
https://www.oocities.org/ziyadhosein/inf.htm
RAGE XL AGP 2X = ati2mpad, PCI\VEN_1002&DEV_474D&SUBSYS_107C10CF, PCI\VEN_1002&DEV_474D
RAGE XL AGP 2X = ati2mpad, PCI\VEN_1002&DEV_474D&SUBSYS_806A1002, PCI\VEN_1002&DEV_474D
RAGE XL PCI = ati2mpad, PCI\VEN_1002&DEV_474F
RAGE XL PCI = ati2mpad, PCI\VEN_1002&DEV_4752
My AGP Rage XL is 474D (VEN_1002&DEV_474D)
NB! J series info for 3DCIF (4.11.2611_rage-3dcif.zip).
J series works only with multiple and different driver installations 5.40x + j series or macxw4+j series, something like that, i just did not test it with clean installation, all new installations with just j series driver, it does not work, because of the mix of the driver files, Thank you Gona.
For my HP Thin Client - T5300 i haven't bought bigger ide 44-pin dom yet, so it is still in dos mode. I have similar, T5700 has faster CPU 😀
Re: VIASBCFG - VIA SBPro configuration tool for VIA VT8231 & VT82C686/A/B chipsets (v0.12d)
For those who have more than one accelerator in one PC can use 3D Control Center (for Direct3D) and OpenGL Switcher (for OpenGL)
http://vogonsdrivers.com/getfile.php?fileid=807&menustate=0
http://www.3dfxzone.it/dir/3dfx/utilities/?objid=3
I hope F1etch will get it work, let us know, Thank you!
With gratitude,
MarxVeix
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
