Formating and partitioning disk for MSDOS 6.22
Reply 20 of 21, by maxtherabbit
Dave Bursik wrote on 2021-02-11, 20:33:
maxtherabbit wrote on 2021-02-11, 20:24:
He's talking about the CDU distro of DOS 7.1 which works great
Sorry, what you mean "CDU distro" ?
The CD image you have with DOS 7.1 was put together by an outfit called the "chinese dos union"
I don't know anything about them, but the DOS works great
Reply 21 of 21, by Jo22
Dave Bursik wrote on 2021-02-11, 17:22:
Jo22 wrote on 2021-02-11, 12:39:
mothergoose729 wrote on 2021-02-10, 20:53:
freedos, DOS 7.1, and DOS mode in windows 9x all have fat 32 support. You can make the partitions as big as 2TB - at least theoretically.
DOS is fat 16. The 16bit address space is 2gb. One way to get around that is to make a bunch of partitions each 2gb in size. I think DOS 6.22 can address as many as four of them, or rather as much as 8 total GBs no matter how you divide them up.
🙂 May I have the patch for MS-DOS 5.0?
Sure, no problem. 🙂
Browsing a harddisk under DOS without using BIOS routines (INT13H)
You'll need a copy of English MS-DOS 5.0, though.
And you need a BIOS that does not limit int13h (it needs to hold 12-Bit cylinder numbers. Virtual PC 2004/2007 is suitable).
See Re: Unable to see more than 2GB of my HDD
MS-DOS 5.0A may not work with the utilities, because they predated it.
Manual patching with a hex editor should also work with DOS5.0A and DOS 6.x, though.
