First post, by DaveJustDave
Someone recently gave me a Toshiba 4010 CDS. Neat laptop, has OPL3.
Problem is there is a BIOS password and it won't boot.
Does anyone have any idea how to reset/remove this?
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 1 of 17, by Rawit
You need to connect some pins on the parallel port for a reset. Quick Google:
"Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25"
I know that there are complete guides out there, maybe this can get you started.
YouTube
Reply 2 of 17, by DaveJustDave
you know, i saw that on one of those scammy Q/A sites, but it just seemed a bit farfetched to me. I guess I'll hack up a spare printer cable and get to work.
Reply 3 of 17, by havli
Simple clear CMOS by disconnecting the internal battery doesn't work?
Reply 4 of 17, by DaveJustDave
Nope tried that. Took it apart, found the CMOS battery (it has two for some reason) and disconnected.
Reply 5 of 17, by MAZter
DaveJustDave wrote on 2019-05-02, 17:55:
DaveJustDave, did that parallel port method work? I have similar problem with Portege laptop.
Reply 6 of 17, by Thermalwrong
It works, I've had to do that on a Toshiba Libretto 50CT and a Toshiba Tecra 8000. The toshiba maintenance manuals have the pinout listed, I think it's called a Parallel Port Wraparound Connector in there, with the pinout listed in the wiring diagrams section.
Reply 7 of 17, by hyoenmadan
havli wrote on 2019-05-02, 19:14:
Laptop generally save security data in a separated separated from nvram values in an eeprom chip. Sometimes you can hard tamper that eeprom short circuiting its pins to erase its contents or soldering a new blank eeprom, but sometimes... If the BIOS doesn't find certain expected data or checksums in them it will never let you boot. That's the case with Thinkpads. Dunno about Toshibas (with Toshiba BIOSes).
Reply 8 of 17, by FazzaGBR
Use a KEY disk - very quick and simple to create and use.
See here: https://www.retrocomputing.co.uk/2019/10/rese … op-bios_18.html
My personal website blog: https://www.retrocomputing.co.uk/ and my new Retro Computing YouTube Channel: https://www.youtube.com/channel/UCL8UT2gm3EvNl2tvomN7reg
Reply 9 of 17, by MAZter
Broke my Toshiba 3330V laptop while trying to reset boot/bios password with LPT/Parallel port device 🙁
https://www.youtube.com/watch?v=WebSYPUN3fo
Reply 10 of 17, by FazzaGBR
MAZter wrote on 2020-02-12, 03:09:
Am I missing something as I've watched the video and it shows the laptop being fixed as the device has done what it is supposed to do and remove the BIOS/CMOS password as it no longer requests a password but instead reports that the BIOS/CMOS configuration settings are not set and you need to go in to the BIOS and set them?
Reply 11 of 17, by MAZter
FazzaGBR wrote on 2020-02-12, 13:58:
Heh, that was joke, laptop actually fixed 😀
Reply 12 of 17, by kleung21
Hi there guys, thanks for all the comments.
I recently picked up a cheap Toshiba 490xcdt (p2 era) and Toshiba Tecra 8000. The 490xcdt had the bios password. Removed both cmos batteries and hard drive, bios password still stays (? eeprom).
ANYWAYS, was going to build a parallel port bypass device (soldering/twisting wires) but read somewhere about someone just tying some wires together that made me think.... Why not just jumper the port directly?
Using paper clips, a right angle wire cutter (to clip the paperclips shorter/cleanly where needed); I was able to wire it up and get it working. I made a video but need to edit it... The only tricky one was the 1-5-10 triple cable which I wired by having a 2nd wire/paperclip touch the one in the 1-10 port.
Anyways, I've uploaded a picture. Works great and saves people from having to buy/build devices to use one off.
Reply 13 of 17, by nfraser01
Glad I found this thread as I've been trying to reset the BIOS password on a recently acquired Satellite 320CDT. The eBay seller neglected to mention this, but to be fair it was sold as Spares/Repair.
I had tried various things including generic passwords and a "key disc" but that hadn't worked. I had heard about the parallel port hack, but was sceptical. kleung21's photol inspired me to give it a try with paper clips and can confirm it worked for this particular model.
Reply 14 of 17, by Yoghoo
The parallel port method also worked on my 310CDT. Used some solder wires as I didn't have enough paper clips. 😀
For future reference note where pin 1 is located. Above pics worked perfectly. First time I mirrored it the wrong way as I looked at another guide without pics. No harm was done but it didn't work of course.
Reply 15 of 17, by dekkit
Yoghoo wrote on 2022-08-05, 09:17:
Out of interest what was the c310T like before you tried this? Did it show anything on screen? Or did it appear dead with just the power led?
Reply 16 of 17, by Yoghoo
dekkit wrote on 2022-08-05, 14:02:
It started normally with a Toshiba splash screen and then a password prompt. I knew the user password but not the supervisor password. After messing around with some Toshiba tools (trying to clear the password) I was locked out completely so needed to do this "hack" to use this laptop again. But even then it will show the password prompt but it will turn the laptop off after 3 incorrect passwords.
Reply 17 of 17, by dekkit
Thanks! Ive got relatively dead toshiba (batteries removed etc but external power) thats gives me nothing. Ive tried this but thought I may have wire pins wrong. Thanks for confirming your experience.
