Ultima VI install error
First post, by ganson316
I have an old CD with Ultima VI and Wing Commander on it. When I try to install it via DosBox, I get into the install shell, but it tells me I am missing 'append.exe' 'subst.exe' and 'join.exe'. It wants my DOS discs so it can retrieve the files, but obviously I don't have those.
Any help would be much appreciated.
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Hmmm. That sounds like an CD with illegit copies of the games, and an installer that tries to simulate the right drive letters using APPEND, SUBST and JOIN.
I am afraid you won't get much help with illegit games here.
I am locking this thread now, but feel free to send me a private message if you feel thread should be unlocked.
_________________
Reply 2 of 8, by MiniMax
Rank Moderator
Moderator
Great Hierophant wrote:
I think he may be referring to a legitimate release of these games, see here:
http://www.mobygames.com/game/dos/wing-comman … e-false-prophet
The games install program may actually require a true version of DOS.
Seems like I was a bit hasty there. Thread is now open again.
_________________
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
Is the install program an EXE or a BAT-file? If it is a BAT-file, could you zip it up, and attach it to this thread?
What kind of system are on using? Linux, Mac, or Windows? If Windows, try installing it from a CMD-prompt.
_________________
Reply 4 of 8, by Great Hierophant
I think the games should be "installed" on the CD, so all you should have to do is to copy the game directories to the hard drive and run install to configure them. I would forget all that nonsense about append, subst and join.
Reply 5 of 8, by ganson316
It's a BAT file, and I'm installing it on Windows. Using the Command Prompt yields the same error.
However, Hierophant's advice worked, thank you so much! I have been wanting to play this game again for years.
Reply 6 of 8, by ganson316
The music doesn't play, but I get the PC speaker sounds fine. It doesn't play in Wing Commander either. Since I bypassed the regular install, I didn't have a chance to set up AdLib or anything. Any advice for this?
Reply 7 of 8, by Great Hierophant
There should be files in each game's directory named "install.exe". You can use those to configure the graphics and sound of each game.
Reply 8 of 8, by ganson316
That worked too, thanks again!
