Dual socket 7 build
Reply 40 of 57, by Sphere478
luckybob wrote on 2021-02-26, 05:56:
Yea that ebay rule is the result of a 5-6 year long forum thread going absolutely tits up. I think the mods let me get away with it because it's usually to answer an inquiry, and never a self promotion listing.
That or they like me, but I doubt that.
I wasn't promoting anything just posting a link to something I was talking about 🤣
Warlord wrote on 2021-02-26, 06:07:
Be interested in looking at the spec sheets between a GT and a MT. I used a MT adapter. Not sure if GT is better or not. PWLA8492MT Thats not going to work for you though as its for 3.3v slots only. I think your board only supports 5v slots. So thats something to consider.
I'll check and see if I can figure out if it's 3.3v
edit: checked both my boards are 3.3v slots
well, some more updates I've tried a few different operating systems and am now going back to using windows xp sp3 it seems to run good but would still like to use 7 instead I keep running into things that don't work like smb1.0 and GPT but have found solutions to those
next thing I wanna tackle is the NIC
prob gonna order one of those intel ones.
killer nic would be pretty cool but can't find one
🖥Craziest socket 7 build on a 430tx chipset
🖥Dual socket 7 build
Reply 41 of 57, by luckybob
No, the tyan has 5v pci slots.
if the notch is in the BACK (rear) its 3.3v if it's in the FRONT, 5v.
the card I linked earlier: Re: Dual socket 7 build
is a universal pci card.
39.12 KiB
Reply 42 of 57, by Sphere478
luckybob wrote on 2021-02-26, 06:39:
No, the tyan has 5v pci slots. […]
I actually tested it with a tester card. it has 3.3v am I missing something?
I ordered one of the cards you linked to btw. will try it out thanks!
Reply 43 of 57, by Warlord
killer nics are shit. Even if they were good like I say the driver uses system resources that were casing like 1% cpu utilization on my quadcore. So just idle on your system it will probably use like 10% or something 🤣.
Reply 44 of 57, by Sphere478
Warlord wrote on 2021-02-26, 08:24:
that's wild. you would think that they wouldn't do that. that's like their whole "deal" lowering cpu utilization... I ordered the intel one
have you talked to others with it? maybe yours was a special case?
Reply 45 of 57, by Doornkaat
Sphere478 wrote on 2021-02-26, 06:57:
The notches determine which signalling voltage is used.
A PCI slot can be keyed for 5V signalling but still have 3.3Vcc present on the corresponting pins.
A PCI card keyed for 5V signalling can require 3.3Vcc to be present on the slot in order for it to work.
Only 66MHz PCI slots use 3.3V signalling.
Universal PCI cards are compatible with 3.3V as well as 5V signalling. They can be either 33MHz only or also be 66MHz capable. I don't think there are 66MHz only cards. The slowest card on the bus determines the bus speed.
Reply 46 of 57, by Sphere478
Okay so that’s like the I/O you are talking about but 5v cards still can get 3.3v I see. So those power cards you sometimes see are for boards that don’t have the 3.3v power pins on 5v slots?
I got it all set up with it recognizing the 12 tb drive and all drivers installed and made a image to save me time if I mess it up again 🤣.
I have a few problems with it still,
It won’t see the 12 or 8 tb drive when I plug it into usb which is actually how I would like to do it for portability reasons
It shows up under device manager but not disk manager or my computer
I got the 12 tb drive shared on sata and I see the dual pentium on my windows 10 network but when I click on it it asks me to log in. Nothing should be asking for a password, I installed smb1 on the windows 10 computers so what am I missing here?
For some reason the 8 tb drive doesn’t show up when plugged into sata even in the bios for the promise. They both appear to basically be the same drive but one with a extra platter. Any ideas?
Reply 48 of 57, by Sphere478
Warlord wrote on 2021-02-27, 01:59:
I think microsoft broke smb1 on win 10, I have never been able to re enable it.
under windows features in add/remove programs? You tried there?
Reply 49 of 57, by luckybob
Because the drive is formatted incorrectly for retro computers. And they likely won't be able to see that big of a drive as well.
Reformat the drive and add a 2nd small (ish) partition for the retro computer. 10gb should be more than plenty.
Reply 50 of 57, by Sphere478
luckybob wrote on 2021-02-27, 02:49:
GPT disks on windows XP SP3 (partially solved)
Reply 51 of 57, by Sphere478
Cut a slot in the motherboard backplane and tapped a hole in the rear bulkhead for the top pci card and moved the promise up there
Got the intel gigabit network card today and it’s installed haven’t been able to mess with it yet though
Also got a internal usb hub and stuck it on the bottom to turn the two motherboard ports into 8 ports which is nice.
I keep having windows xp stuck on the scrolling bar part during startup
I can get it to boot by telling it to use last good settings that worked but I keep having to tell it to use those settings on every boot.. ideas?
Reply 52 of 57, by SquallStrife
A lot of these difficult-to-track-down hangs and crashes are screaming "bad RAM", or at least "un-cooperative RAM" to me.
As you know, I have the same mobo in my Dual-S7 system.
I had a lot of issues with my board at first, it took me hours of trying out different RAM before I found a set that works correctly. Mind you, I only have 256MB.
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 53 of 57, by Sphere478
SquallStrife wrote on 2021-03-02, 04:03:
yeah, that's what it was.
I got xp loaded on it and am now dealing with XP related issues. 512mb is working in slots 1-4 128mb x 4 it was detecting 768 but that turned out to be a glitch and the source of my issues along with not using slots in ascending order from 1 up (I was using slots 3-8) now that I'm only 512 and using slots 1-4 it's fine I originally used 3-8 cause before the bios update it was the only combo that would show 768 but after bios update 1-6 also work. whereas before it only showed 600 something in those slots.
are you running the jan bios?
Reply 54 of 57, by SquallStrife
I'm not sure, I'd have to fire it up and check.
Glad you got it stable though! 😀
Reply 55 of 57, by Woody72
SMB1 is 'kind of' fine in Win 10. With my main desktop I just had to enable it in Windows 10 features by ticking the box. I couldn't get it working with a password (a quick Google suggests this is a fairly universal issue) but it works fine if you leave the password field blank. I just bought a new laptop at the weekend and upgraded Win10 Home to Pro and SMB 1.0 was already ticked in Windows 10 features.
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
Reply 56 of 57, by Sphere478
I got the intel NIC working on the dual pentium a while back and it was faster but I can't find where I posted results..?
I am now trying a Killer NIC and gonna see how it does.
