First post, by Carstenl
I have found this card, but i have not been able to find anything about it.
On the back of the card it says " Videograph"
Perhaps some of you have seen such card before ?.
Regards
Carsten
Reply 2 of 4, by debs3759
I'd be willing to bet that the missing chip is the one that does the bulk of the processing. No idea what the card is though.
Reply 3 of 4, by wiretap
You're missing the 110MHz clock oscillator near the card bracket, the large chip which should be a HD63484CP8, and a few capacitors that I see at a quick glance.
If you look at the pictures, the 3 coax outputs are for RGB, probably for hooking up to a CRT projector or similar business/industrial grade monitor.
http://vgamuseum.info/index.php/cards/item/17 … i-hd63484-acrtc
My Github
Circuit Board Repair Manuals
