First post, by Zork
- Newbie
Hi, after obtaining a copy of "James Bond: The Stealth Affair" I attempted to run it in DOSBox using version 0.63 with VGA features and 3000 cycles. At first, all goes well, and I click OK on the first screen, but when the game goes to the early copyright protection screen, the game crashes. If I remember correctly, I did not have this problem with version 0.62 of DOSBox but I could be wrong. I have also tried an identical game called Operation Stealth (The game was released in the UK as Operation Stealth and in the US it was released as James Bond: The Stealth Affair) and Operation Stealth seems to work fine without any problems. Does anybody know how I might go upon fixing this? Thanks 😀
"You have entered a dark place. You are likely to be eaten by a grue."
