Video advice
First post, by simonh27
Over the past couple of months I've been collecting old computers from Craigslist etc
I plan on putting together a DOS 6.22 machine and have a pentium II 350mhz with an agp 440bx motherboard
I have a selection of video cards and was wondering what the consensus would be on the most "compatible" card I have be.
S3 Virge gx 2mb (pci)
Matrox millennium II with 16mb wram
Nvidia Riva tnt 32mb
Nvidia Riva tntm64 32mb
Radeon 9000
Radeo 7500 (pci)
Nvidia fx5200
Nvidia fx5500
Looking around I see some are Vesa 3.0 others Vesa 2.0 and you can use univbe to get to Vesa 3.0 although I'm not sure how important the Vesa version is for dos
Thanks ahead of time
Reply 1 of 6, by Joseph_Joestar
From the cards you listed, the S3 Virge is the most compatible one with regards to DOS games. Followed closely by the Nvidia cards, then Ati and Matrox. See here for more details: https://gona.mactar.hu/DOS_TESTS/
As for VBE 3.0, it allows you to run VBEHz and similar tools which can set the refresh rate of certain DOS games to higher values. This is useful if you are using a CRT monitor and want to play WarCraft2 at 120 Hz for example. The S3 Virge also has a custom tool which can increase the refresh rate, but that one caps out at 85 Hz.
My retro stuff
Reply 2 of 6, by DundyTheCroc
I use S3 Virge/GX for DOS gaming and yes, it is great, no problems at all.
Reply 3 of 6, by simonh27
Thanks...I guess the pci card it is...feels weird because usually you want the "best" option
Reply 4 of 6, by Warlord
whats the problem with the TNT2
Reply 5 of 6, by simonh27
Warlord wrote on 2021-03-06, 00:33:
Nothing it works fine, but my knowledge is limited s I was asking for advice to avoid issues down the line
Reply 6 of 6, by The Serpent Rider
VBE 3.0 card can be tweaked by VBE 3.0 utilities and does not require strict chip identification to tweak refresh rate or resolution. VBE 2.0 cards are limited only to their chip specific utilities or UniVBE.
That leads to a problem with lazy ass manufacturers like ATI. ATI didn't integrated VBE 3.0 on cards after ATI Rage Pro and they cannot be tweaked, because UniVBE does not support them.
