First post, by Agathosdaimon
Hi!
I recently got the physical 3.5 floppies for Fighter Bomber (aka Strike Aces)  as this seemed the only way to get all the missions.
I have been able to copy the contents off the disks and run them from the HD with Dosbox , however a weird thin happened that i cant explain - when i first did this and played the game at the bottom of the main menu was a button to select "Practice" or "Tournament" in practice mode all the game missions are playable, all the locked menus open up, whereas in tournament they must be completed in order.
I just went back to the game today, but now that button is missing, i cant select practice mode (I can play those missions from the usermissions folder fortunately) but that main menu button has disappeared
how is this possible?
