First post, by Glidos
Here's a new version of the Capture/Equiv tool. It can capture Unfinished Business TUB files
    GenEquivMap_v1_05.zip
    147.87 KiB
    280 downloads
    V1.05 of the equivalence tool
Reply 5 of 13, by Antonijadis
Well, some textures are replaced by others. I have Sold out version of TR and everything work fine with my original equiv. file. When I made new one (from my original and your version one) and replace original one with it, I got textures that are mixed. I haven't this problem with JC textures and equiv file in his version. Here it is.
    equiv.zip
    139.7 KiB
    345 downloads
Reply 7 of 13, by Antonijadis
Well, when I generate repets.log file from my textures pack I receive file that shows many repeated textures, but when I visual compare each of them they are not the same. For example many textures of the letters are shown like they have copy in textures that are totally different of them. You can check it by yourself.
    repeats.zip
    5.63 KiB
    584 downloads
Reply 8 of 13, by Glidos
Repeats don't mean the textures are the same. It means Glidos is being told - by the mapping file and the equiv file - of mulitple replacements for a single texture.
What about if you run the test with your original equiv file?
Reply 11 of 13, by Antonijadis
The eror has been caused by equiv file. It seams that Glidos mix my equiv and new one even I renamed it. So there can't be more than one equiv no mater what is it name.
Reply 12 of 13, by Glidos
Glidos will read all the files to see what's inside them. So if you can't disable an equiv file by renaming it. You need to take it out of the folder.
... sorry if that makes no sense: I may have misunderstood what you said.
Reply 13 of 13, by Antonijadis
Exactly. It's OK now. 😀
