First post, by MartinGladis
Hello to all,
I tried to start Tomb Raider I under Windows 2000 with Glidos. But I got the message:
wrong version of tomb.exe.
Who can give me a hint?
Best regards, Martin Gladis
Reply 1 of 2, by Kaminari
Is your CD in the drive when you run TR from Glidos? Did you replace the original tomb.exe with the Voodoo one available here?
Reply 2 of 2, by NoGood
Maybe you're not using a legal version of Tomb Raider? Or maybe you have to adjust the .ini file to point to the dir where TR is installed ...
