First post, by sf78
I ran into this weird problem trying to setup this card:
https://upload.wikimedia.org/wikipedia/common … deo_card_02.JPG
The config utility ID's it as !DHQ0101 and that CFG file is nowhere to be found. 😦
All the sources say it should have ID of !CPQ3001. 😕
Any ideas why the ID would be something completely different than what Compaq cards use? I don't suppose there is a generic VGA config file that I could use as that would conflict with the cards actual ID right?
