First post, by CBM
so I found an old motherboard I have had stored in a wooden shed of mine since 2005 or so
actually I found quite a few but this is the one I have chosen for a 98se build Id like to do
I added memory and a graphics card and connected a speaker, some power and a display
the cpu fan spins up buit there are no beeps and the minitor reports that there is no signal
I troed with various combinations of memory and graphics cards also cards and memory modules that I know are working in other systems
what can I do?
speaker connectr pinout is...
1 spkr
2 not connected
3 ground
4 5v
the speaker is connected to 1 and 4
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
Reply 1 of 13, by CBM
it has a duron cpu
Main PC SPECS:
PSU: Corsair RM850
Reply 2 of 13, by Con 2 botones
I guess you´ve already tried with another CPU and reseting the BIOS.
I can´t see bulging capacitors in the picture.
Reply 3 of 13, by Towncivilian
Replace the CMOS battery if you haven’t yet. Some motherboards refuse to boot without a good one installed.
abit BX-133 RAID, P3-S 1.4Ghz, 768MB PC133, Radeon 9000 PRO, AWE64, 2x40GB RAID1, Sony SDT-9000 & Connor CTD-8000 SCSI DDS2 DAT drives, Realtek 8169 1GB NIC, Adaptec DuoConnect AUA-3121, Win2k SP4
Depeche Mode Live Wiki
Reply 4 of 13, by CBM
it just got reseated with fresh termalpaste and a new cr2032... but still no life
havent tried another cpu yet though
Main PC SPECS:
PSU: Corsair RM850
Reply 5 of 13, by CBM
just tried a different cpu and multiple cmos resets and still no change
however
the cpu I used still works in the board I took it from so atleast the board isnt killing components
and yes the cmos battery is a brand new one
Main PC SPECS:
PSU: Corsair RM850
Reply 6 of 13, by CBM
I also tried another mainboard with a k6 cpu installed
it is an msi ms5169
it gives me continous short beeps when started
when I REMOVE one of the ram sticks then there are no beeps but there is still no signal other than the fans coming to life just like the ecs elitegroup board
Main PC SPECS:
PSU: Corsair RM850
Reply 7 of 13, by CBM
pictures
I really really want to save these boards especially the ecs elitegroup board
is there anything else I can do?
Main PC SPECS:
PSU: Corsair RM850
Reply 8 of 13, by CBM
pic of ecs board without cooler
page with beep codes
https://forum-en.msi.com/faq/article/bios-beep-codes
doubt its validity though since the msi board stopped beeping after the faulty ram stick was removed
and the webpage in this links claims that repeating short beeps is a power error when it clearly had a mem error instead
however both still have unknown errors that prevents them from booting
Main PC SPECS:
PSU: Corsair RM850
Reply 9 of 13, by weedeewee
I have an identical board k7s5a,
stopped booting,
had bad caps.
replaced caps, smoked cpu.
verified voltage on cpu pins ( 1V1 1V2, can't remember exactly), verified ok.
tried other cpu, smoked again.
haven't tried anything more since.
addendum: if those caps on your board are G-luxon brand, then they're bad and should be replaced. ...
Do not ask Why !
Reply 10 of 13, by aaronkatrini
Also a good thing to do would be spray the memory and expansion slots with de-oxyd spray, it's only 5 euro from the hardware. I've seen many brands of motherboards that don't use gold contact pins but bronze ones to save a few pennies, and guess what... after 20 years later surely that motherboard won't post anymore, but sometimes you might get lucky and see the post screen...
Also that mobo might be at the "golden era" of bad caps... so probably some of them are already gone...
Reply 11 of 13, by CBM
weedeewee wrote on 2021-03-26, 14:20:
I have an identical board k7s5a, stopped booting, had bad caps. replaced caps, smoked cpu. verified voltage on cpu pins ( 1 […]
stopped booting,
had bad caps.
I doubt it smoked the CPU because the alternate CPU I tried still works after I put it back in the motherboard I borrowed it from
But the caps might likely need replacing as you said.
aaronkatrini wrote on 2021-03-26, 15:01:
de-oxyd spray? I will try that as well as replacing the capacitors.
Main PC SPECS:
PSU: Corsair RM850
Reply 12 of 13, by Towncivilian
The spray is properly named “DeoxIT”.
Reply 13 of 13, by verysaving
That caps had to be replaced even when the board was brand new ...
