First post, by jhhoward
This is something that I hacked together by modding the existing 2 colour CGA driver - it enables the colour burst bit and has a modified look up table for colour translation. I have only tested this in DosBox-X as I don't actually have a CGA machine with composite output. The CGA composite colours don't quite have a good match for all the EGA colours but I tried to fit them the best I could.
To use, just add the CGACOMPO.DRV file to your game directory and edit the RESOURCE.CFG to read:
videoDrv=CGACOMPO.DRV
Reply 1 of 20, by darry
jhhoward wrote on 2021-03-31, 14:14:
This is something that I hacked together by modding the existing 2 colour CGA driver - it enables the colour burst bit and has a […]
That looks great, IMHO . The different colours actually give the game a much more pleasant and less sterile look .
Nicely done!
Reply 2 of 20, by Benedikt
Does the driver not show up in the installer?
I think it should, provided that you modified the strings in the file header.
Reply 3 of 20, by jhhoward
Benedikt wrote on 2021-03-31, 16:11:
Yes it should show up in the installer as 'CGA with composite color output'. I mentioned the instructions about editing the config file directly because the modern re-releases tend to have the install / setup programs stripped from them.
Reply 5 of 20, by MusicallyInspired
Heck yes.
EDIT: I tried this with the EGA SCI1.0 games and it works, but like the older official CGA drivers, it doesn't like scrolling screens. Which means it won't work for KQ1SCI either.
MuntVSTi Editor
FB-01 tools
Github
SC-55 Packs
Reply 6 of 20, by jhhoward
Took another look at the palette mapping and think I have generally improved it. New version is attached to this post
Here are some comparison screenshots of original EGA version vs composite CGA version:
Reply 7 of 20, by darry
I like both. Hard to say which one I prefer .
Reply 8 of 20, by MusicallyInspired
For KQ1, the first release looks a bit better. SQ3 definitely looks better with version 2 though.
MuntVSTi Editor
FB-01 tools
Github
SC-55 Packs
Reply 9 of 20, by Benedikt
MusicallyInspired wrote on 2021-03-31, 19:19:
Heck yes.
That can be patched in. The newer version has an additional function, i.e. the scroll function, and a matching additional entry right at the end of its jump table.
If that additional entry is missing, but the game expects it to be there, funny things happen.
Reply 10 of 20, by jhhoward
Benedikt wrote on 2021-03-31, 21:50:
I had a go at trying to patch it in but it still locks up when scrolling (testing SQ1 EGA remake). I appended a function at the end of the driver and updated the jump table to include the address of the new function. I used your FOSS driver code(https://github.com/roybaer/foss_sci_drivers/b … er/src/pcplus.s) as a reference. I tried:
- Wrapping the update_rect function exactly like you did
- Stubbing the function entirely by just pointing to a ret instruction
- Tried using the scroll function from a newer CGA driver, which basically wraps the update_rect function with a few extra steps, looks like this:
and bx,0F8h
add dx,7h
and dx,0F8h
mov si,di
call update_rect
ret
I guess I could try stepping into the code with the DOSBox debugger to see how it locks up. Maybe the driver uses the 2 bytes immediately after the header so the jump location gets stomped on? I could try modding a newer CGA driver but the format of the look up table is different so I'd have to reverse engineer it again.
One thing I noticed is that the header on the actual driver has 3 extra bytes at the beginning of the file before the 'magic number' signature (00 21 43 65 87 00). Do you know what these are for?
Any suggestions?
Reply 11 of 20, by Benedikt
jhhoward wrote on 2021-04-01, 12:28:
Any suggestions?
That is a jump instruction to the dispatch routine. Execution starts right at the beginning of the file.
If everything else fails, we could still try to transplant your work into a new CGA driver based on pcplus.s.
Reply 12 of 20, by jhhoward
Benedikt wrote on 2021-04-01, 13:26:
Ah yeah that actually makes a lot of sense now that I look at it!
I ended up patching the newer CGA driver and now it works with the later SCI games since it has the scroll function implementation. I've attached the new version of the driver that should work for more games.
One thing I have noticed though is that the mouse cursor hot spot position is incorrect for EGA versions of SQ1 remake and SQ4. Is that something that works properly in your driver?
I would say that due to the nature of the artwork in the EGA versions of SQ1/4, the driver is pretty ugly due to the way the backgrounds are dithered. Here is a VGA/EGA/CGA comparison:
Reply 13 of 20, by jhhoward
I was experimenting with dithering - specifically for creating a dark grey as it is missing from the CGA composite palette.
I also experimented using dithering and scanlines to more closely match the EGA palette, although the result is very noisy! I wonder how they would actually look on a real CRT display from a CGA card.
Reply 14 of 20, by Benedikt
I guess there is only so much you can do when it comes to picture quality.
But maybe you could try the opposite direction and try to turn existing dithering into solid colors – or coarser new dithering – by processing pairs of pixels at a time.
This could help with SQ4.
Reply 15 of 20, by jhhoward
Just for reference I've attached the dither versions from my last post:
CGACOMPO.DRV - Mostly the same as the previous version except that dark grey is emulated with a dither pattern
CGADITH.DRV - Dither patterns to simulate EGA colours
CGASCAN.DRV - Scanline patterns to simulate EGA colours
Reply 17 of 20, by mmasias
This is impressive... Thanks for the effort! 😀
Reply 18 of 20, by Jinxter
I did some testing with the three drivers on my EuroPC1. I am using a MCE2HDMI (from Serdashop) to create the CGA composite colors.
Since the EuroPC supports Plantronics, I am using that for reference.
Of the Composite modes, the plain composite gives the clearest image, but the dithering gives more accurate colors. The scanlines version i don't see a use for. Of these three Composite modes I would use plain composite, even with the "wrong" colors.
BTW: Thanks for your excellent drivers. Big fan of your work.
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
