First post, by kleung21
Hi there all,
I have a compaq lte 4/50cx and I'm having a bugger a time getting the PCMCIA => CF adapter working.
I have Dos6/Win3.1 installed.
I tried ATAENAB.exe driver. Still didn't work (no device detected).
If anyone has any solutions or suggestions on what I need to get the PCMCIA recognized and working, I would appreciate it.
Does anyone recall what drivers are required to get it up and running.
(the floppy drive is dead on this laptop and there are no usb slots so I was originally planning to use the CF adapter to transfer files).
On another note, I installed Laplink5 and I forgot how great/powerful it was. It can remote install itself and after testing, it works GREAT to transfer files. I'd still like to get the PCMCIA=>CF working so if anyone has any ideas. .. Greatly appreciated.
Reply 1 of 5, by Bondi
Did you try to find Compaq PCMCIA drivers online? I never owned one, but I suppose they should be available.
ATAENAB usually worked for me, but AFAIR I had to bypass config.sys and autoexec.bat.
You may also try universal Cardsoft drivers.
CardSoft for DOS release 5.30.10.rar
579.51 KiB
449 downloads
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 3 of 5, by kleung21
I managed to get the PCMCIA slot working in the end
ATAENAB did work in dos
Installed Windows 95 and that has the correct drivers to detect and load PCMCIA
Reply 4 of 5, by pentiumspeed
kleung21 wrote on 2022-02-07, 08:14:
Forgot to report your solution to get this working in DOS. I have LTE ELITE 4/75 too that I wanted to use PCMCIA CF adapter working.
Cheers,
Great Northern aka Canada.
Reply 5 of 5, by kleung21
pentiumspeed wrote on 2022-02-07, 13:50:
Cheers,
Hi there. I did get it working recently and posted the solution in the Compaq LTE image thread. My solution/post is on page 2 and details the config.sys modifications and files that will be required.
Tested and working with PCMCIA=> CF and 16bit PCMCIA sound card on Compaq LTE Elite 4/50cx (dos 6.22/win31)
(Factory image) Compaq LTE Elite 4/75CX Laptop (90s) with Windows 3.1
