First post, by stuntgoat
I am stoked on DosBox .065
I need single key keyboard shortcuts for 2 to 4 letter character entries. besides the function keys.
ie when i press 'q' dos should recieve 'qunq'
I press 'w' the program recieves 'wm'
Ideally, only when capslock is on.
I can make a .keylayout file for OSX and choose a new layout using:
http://wordherd.com/keyboards/
It works in all programs i have tried so far[the terminal shell, text editing programs etc]; but not in dosbox.
I also tried Ukelele. Works, but not in dosbox.
I also have a Kensington Ci20 mouse and it can program keystroke patterns [like 'qunq' and 'wm'] with the extra 3 buttons as well as chords (2 buttons at the same time): it works fine in dosbox and everywhere else.
my .conf is attached.
my unit:
http://support.apple.com/specs/powermac/Power … t_Ethernet.html
256 MB
Type: SDRAM
Speed: PC100-222S
I read the read me; tried scancodes=true/false.
i tried to edit with keymapper but it appears not to have the functionality I need and would like to have with .keylayout files.
thanks for the great software.
cheers
