P55T2P4 Cache problems
First post, by ajdrenter
I've recently acquired a P55T2P4 for really cheap for parts and I've built a 233MMX system with it. This board is the 256KB PB model with a COAST slot. When I set the jumper for 512KB and insert a coast module, none of the L2 cache shows up. If I boot up without the coast module and with the L2 enabled, the motherboard will hang after post, right before trying to boot a boot device. If I disable the External Cache in setup, the motherboard will once again boot and work properly. I flashed the latest BIOS, with the 128GB HDD support, before I realized the cache wasn't working. Has anyone ever had this problem, and if so how did you solve it?
Reply 1 of 7, by Repo Man11
Do you have the tag RAM installed? https://www.tomshardware.com/reviews/oldie-tuning,216-5.html
More information on COAST modules and tag RAM: http://library.mobrien.com/Manuals/MPRM_Group … p55t2p4.htm#TAG
Reply 2 of 7, by auron
COAST compatibility issues are commonplace, there were different standards with regards to tag RAM on the module etc. and not all modules will work in all boards. try to get a different module, like the original asus one.
Reply 3 of 7, by ajdrenter
Repo Man11 wrote on 2021-04-17, 21:32:
I don't have a separate tag ram chip installed. The coast module I have has two SRAM chips and two other chips. When it is in the board and the board is jumpered for 512KB it shows 0KB. I'll get a picture of it later.
Reply 4 of 7, by ajdrenter
auron wrote on 2021-04-17, 21:32:
Yeah they seem a bit scarce. I will get another module to try, but I am thinking I might have bad cache on the board as well. Without the coast module and with onboard cache enabled the system hangs.
Reply 5 of 7, by Repo Man11
If the board's cache is faulty you might have little choice other than getting a K6-2+ or 3+ since it doesn't seem likely to me that you would be able to use a COAST module without enabling the board's cache.
Reply 6 of 7, by ajdrenter
Repo Man11 wrote on 2021-04-18, 02:17:
Do you think I could get comparable performance out of a K6-2 with no level 2 cache as I would with a pentium with cache? The K6-3 seems a lot more scarce.
Reply 7 of 7, by Repo Man11
I don't know where you are, but K6-2+ 450 CPUs are on Ebay for less than $30.00 with shipping in the US. That would completely solve the L2 cache problem, and give you any speed you like - up to 500 MHz, and down to 486 speeds by lowering the multiplier and disabling the cache. It would also allow you to install up to 512 megabytes of RAM fully cached if you wanted to.
As to comparing a K6-2 at 450 to 500 megahertz with no L2 to a 233 MMX with L2, I really cannot say, but someone has likely made that comparison in this thread: Let's benchmark our systems with caches disabled
