First post, by vkcpolice
Hi all was setting up a old Pentium with win 98 and i was using philes computer lab easy dos mode menu when my pc got stuck in a boot loop where it would continue to load his menu after a restart and i could not get back into windows i fixed this by clearing out everything in the system config and autobat files windows now loads fine however now every time before boot i get C:\
c:\
c:\
does anyone know what the default system config and autobat files are supposed to have in them?
everything works fine its just my ocd wants it to be correct 🤣
does anyone have a file from a default install of win98se
thankyou
Reply 1 of 12, by Woody72
This is from my Windows 98SE computer.
Autoexec.bat:
mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi)
mode con codepage select=850
keyb uk,,C:\WINDOWS\COMMAND\keyboard.sys
Config.sys:
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=044,850,C:\WINDOWS\COMMAND\country.sys
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
Reply 3 of 12, by weedeewee
add an
@echo off
as the first line in your autoexec.bat
and loose the display.sys line and the two mode con lines.
Do not ask Why !
Reply 4 of 12, by chinny22
The post by Woody72 is just setting dos for the UK region. You can delete all of it and I'll just default back to USA. (or google the correct line for your region)
If your booting into Win98 ideally you don't want anything, Win9x only needs entries for anything lacking 9x drivers or compatibility for dos games within windows
Reply 5 of 12, by vkcpolice
does anyone just have a file i can copy and paste? im a little confused now as to what to put in there. i guess i could just leave as is as i said win 98 now boots up fine its just the annoying text on screen
Reply 6 of 12, by Jorpho
vkcpolice wrote on 2021-04-19, 10:35:
What exactly did you clear? The files are named config.sys and autoexec.bat. (You can easily open them by running "sysedit" from Start->Run.)
If you emptied the wrong files then that might explain what are you seeing. (I guess your ocd doesn't want your posts to be correct..?)
Reply 7 of 12, by kjliew
For Win98/98SE I would just do the bare minimal.
They are from my Win98 VM clean image.
AUTOEXEC.BAT
@echo off
set DIRCMD=/OGN
lh doskey /insert
CONFIG.SYS
DEVICE=C:\WINDOWS\setver.exe
Reply 9 of 12, by Jorpho
vkcpolice wrote on 2021-04-20, 05:33:
i clearly stated that i cleared the text in the autobat and sys config files...
Yes, and there is no such thing as an "autobat" file. There is a file named "autoexec.bat".
If you're editing a file named "autobat", then you are editing the wrong file.
Reply 11 of 12, by chinny22
vkcpolice wrote on 2021-04-20, 04:12:
As I said you don't actually need them. just delete or if you want a backup rename or move to a folder
If you do want to edit them for whatever reason they are just text files, so open them in notepad (you will need to change file type to show all files)
