Reply 38920 of 58922, by imi
where there is a will, there is a way ^^
Reply 38921 of 58922, by chrismeyer6
I've seen similar before. It's really fun to see the stuff people come up with.
Reply 38922 of 58922, by RandomStranger
I did something similar once when I broke the heatsink bracket on my s478 motherboard. Only with rubber bands.
Reply 38923 of 58922, by vad4r
Arrived today: goldfinger device clone
The attachment index.jpg is no longer available
vae victis!
Reply 38924 of 58922, by PC@LIVE
Ordered this PCI Video Card yesterday.
This is an 8MB ATI Rage XL PCI.
Costing less than $ 10, it will probably arrive next month.
I will use it on a socket 7, probably in a TX or VX, or in a VIA VPX.
I think 8MB can be better than the cards I use alone 2MB.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 38925 of 58922, by luckybob
Those ati rage XL chips are actually REALLY quick dos video cards.
Reply 38926 of 58922, by pentiumspeed
I found quality version of PCI Rage XL p/n 109-72300-10 by chinese seller for 25 cdn.
Cheers,
Great Northern aka Canada.
Reply 38927 of 58922, by Ydee
PC@LIVE wrote on 2021-04-30, 21:31:
...I will use it on a socket 7, probably in a TX or VX, or in a VIA VPX....
That's exactly why I used to buy Rage Pro LT, only the boards were with SiS chipsets (PC Chips M590 and Asus P/I P55SP4) and unfortunately, no picture. The card itself is functional, it works without problems on other boards with other chipsets, but there is usually an AGP port and therefore more suitable options.
Reply 38928 of 58922, by dataino.it
Arrived yesterday my first 3dfx need recap and fix , but for 20 euro ..
Reply 38929 of 58922, by Repo Man11
I was contemplating the 4 hour round trip drive to buy one or both of these cases, but when I clicked again, both posts had been deleted. Just as well.
Reply 38930 of 58922, by appiah4
Well, there is not much to say..
he-chose-poorly-2-1.jpg?w=768&h=384
Reply 38931 of 58922, by GigAHerZ
GigAHerZ wrote on 2021-02-09, 21:15:
And a basis for my "higher-end" pentium 2 class machine. 15€
A ChainTech 6ESA2 motherboard, which has ISA, PCI and AGP slots and has integrated ESS Solo-1 sound card.
I didn't know it before i got it, but it also had one of the most desirable Slot1 celeron - Celeron 300A. Definitely will try to overclock it.
Now got a similar kind of "hassle-free" pentium 3 (Socket PGA370) class motherboard - Chaintech 6AIA2. Also has all the requirements ticked i have:
mATX
Good DOS compatible integrated sound card (Again, ESS Solo-1)
AGP, PCI and ISA all present on the board.
Cost me under 10€ shipped.
Reply 38932 of 58922, by LewisRaz
Won these 2 motherboards on ebay nice and cheap. Interested mostly in the highly integrated S7 board that I have IDed as this: http://www.win3x.org/uh19/motherboard/show/8103
Should make an outstanding DOS machine in a nice small MATX case... as long as it works.
The other one just seems like a basic P4.
I also got a £5 mystery box from FB market which, while still worth more than £5. Isnt all that exciting. (1.05ghz athlon, built in vga, sound)
Both are pics from the sellers.
My retro pc youtube channel
Twitter
Reply 38933 of 58922, by PC@LIVE
Ydee wrote on 2021-05-01, 09:06:
As a similar VGA to yours, I have a pair of 4MB ATI 3D RAGE II PCI.
I had put one away some time ago because it had problems, but reviewing it in the past few days, maybe I would have an idea of ​​what caused the problem.
They could be polarized capacitors (tantalum), I need to check them and replace them (as soon as possible).
The card is an ASUS 3DP-V264GT2 / TV, if I can fix it it should be fine in an iVX iTX, or VIA VPX PC.
Regarding SiS (chipset), I don't have S.7 cards with this chipset, but I remember they proposed one in the late 90's, it was not suitable for my needs, and it was not supported by the Hauppauge Win-TV card (it required Intel chipset ).
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 38936 of 58922, by pete8475
LewisRaz wrote on 2021-05-03, 12:28:
1.05ghz Athlon? That's likely a 1.4ghz CPU with the FSB set incorrectly.
aka pete4237.5
Reply 38937 of 58922, by Miphee
pete8475 wrote on 2021-05-04, 19:11:
Or a malfunction. Markings on the caps means that someone already tried to fix it.
Reply 38938 of 58922, by LewisRaz
yea its actually an athlonxp 1500+
Twitter
Reply 38939 of 58922, by imi
this nice trio of boxes arrived recently :3
I really like the simplicity of the old style gravis boxes
The attachment hardware40_25.jpg is no longer available
The attachment hardware40_25b.jpg is no longer available
also couldn't pass this one up ^^
same as my very first keyboard from 1989 but in beautiful black and grey.
The attachment hardware40_26.jpg is no longer available
The attachment hardware40_26b.jpg is no longer available
