IBM G74 Black Rare Monitor No Video
First post, by thegenerallee86
I am having trouble with an IBM G74 Monitor that is the rare black one and it powers on and the light is green but get no video not even the OSD I can hear normal crt sounds and then it goes into standby it clicks and then It acts normal if the computer is not turned on it will go into stand by like it should with an amber light and then turn green so I know it is getting the video signal just no video or even On Screen Display does not show either!
Reply 1 of 23, by chrismeyer6
That sounds like it could be an issue with the tube itself or hopefully just a lose connector inside. But your going to have to open it up and take a look inside. As long as your careful and work safely you'll be fine looking around inside. If you do open it definitely post some pictures so we can all get a good look and hopefully help you solve the problem and get it working.
Reply 2 of 23, by thegenerallee86
Yeah I will and I don't know why I've had such bad luck with CRT Monitors off eBay lately, I will definitely take it apart tomorrow and will post pics and see what is going on hopefully something simple
Reply 3 of 23, by thegenerallee86
Here are the some photos of it after I opened it:
Reply 4 of 23, by thegenerallee86
More Photos of the inside:
Reply 5 of 23, by thegenerallee86
and some more Photo's of the inside
Reply 6 of 23, by thegenerallee86
and the last set of Photos Here:
Reply 7 of 23, by Miphee
Failed flyback or dry caps in the power circuitry. Those Teapo caps are crap, replace them in the power circuitry first.
If you hear the screen crackling when you turn it on then the flyback is probably fine.
Reply 8 of 23, by thegenerallee86
Miphee wrote on 2021-05-05, 11:18:
I noticed now that I opened it up and plugged it in and turned it on it'll make a click sound after a few seconds and the screen doesn't feel static or make the crackling sound either. But I did notice before it was making that gong like sound that most CRT's make when you turn them on before I opened it up.
Reply 9 of 23, by thegenerallee86
Just an Update I found a blown fuse could that cause the issue where it gets power but screen does not turn on and No OSD? The Fuse is completely white!
Reply 10 of 23, by chrismeyer6
That could be it. But I would definitely check it for continuity first as some fuses are opaque.
Reply 11 of 23, by thegenerallee86
Well I think I may Give up and recycle this one but I noticed that when it turns on it does the degauss sound and makes a click sound after that after it's been shut off for a while?
Reply 12 of 23, by chrismeyer6
If it's degaussing the screen that should mean the tube is ok. I'm wondering if it's just something in the video section. Bad caps or a bad/cracked solder joint.
I'd hate to see you trash it if it's a simple fix.
Reply 13 of 23, by thegenerallee86
chrismeyer6 wrote on 2021-05-07, 12:20:
Yeah Me too! I also noticed that I don't feel no static on the screen or hear crackling but it clicks once and kind of sounds metallic? I'm pretty sure it was a new Monitor in an Open Box too that has been sitting and never used.
Reply 14 of 23, by chrismeyer6
I've had quite a few crts that didn't have the static on the screen when powered up. I'd suspect maybe dried out caps or something simple. Cause from your pictures everything looks good and clean and I can't see any damage to the tube or neck area.
Reply 15 of 23, by chrismeyer6
Just had another though. I'm wondering if the vga cable got damaged somehow. We have an IBM LCD monitor at work and if their is no video signal you can't bring up the osd or anything but as soon as it has a signal you can bring up and use it's osd.
Reply 16 of 23, by thegenerallee86
chrismeyer6 wrote on 2021-05-07, 12:42:
Never thought of that But am wondering cause it does come out kind of angled on the back a little bit and where would I find one?
Reply 17 of 23, by chrismeyer6
You might not be able to get an original replacement cable. But you should be able to buy a VGA extension cable and cut an end off and use that to replace the original cable.
Reply 19 of 23, by chrismeyer6
That should work.
