pentiumspeed wrote on 2021-05-07, 16:37:
Not this amd Dell computers. There are two types of heatsinks, one for intel one for AMD due to processor package height and socket are different.
Only one heatsink for Optiplex 740 MT. AMD boards has socket normally posititioned, while Intel boards has processor rotated 45 degrees and different height.
Cheers,
Looking at pictures of both, the height looks to be about the same.
If the shroud is different, then maybe switching the heatpipe cooler to the heatsink shroud would work.... or modifying the shroud. OR even spacering the heatpipe cooler up a tiny bit on the stock shroud would work.
It has been years since I laid hands on one of the AMD Dell system like that so I am not entirely sure. It should definitely be possible to make the better cooler work with the AMD system though since the mounting brackets for the shroud should be exactly the same.
The 45 degree angle is not going to make enough of a difference to matter. The CPU die is in the middle and way smaller than the heatspreader.
Edit:
Looking at the mounting holes for your motherboard and for an Optiplex 780 motherboard, it looks like you would need to reposition the cooler in the shroud.. figure out how much you need to reposition the cooler to be centered over the CPU and then drill new holes to mount the cooler in the shroud and possibly remove a bit of other plastic which would prevent the repositioning.
The LGA775 socket is centered front to back while the AMD socket is not.
