First post, by cyclone3d
- l33t++
I just picked up a Roland SC-88 for cheap. Knew it was not working properly before I bought it.
All controls and the display works.
MIDI In is responding to data as is reflected on the screen.
I'm just not getting any MIDI audio output from the headphone jack or the rear outputs.
Pushing the volume knob for preview shows up on the screen but there is no output.
When turning the input volume knob on the back of the unit, I do hear a tiny bit of scratching through the headphones.
I do get audio through the headphones if I output from my computer to the phono input jacks on the SC-88.
What I have done:
1. Reset to factory defaults
2. Replaced battery
3. Re-soldered the connections for the headphone jack as all 3 connections were obviously cracked / loose.
4. Verified continuity of the connections of the headphone jack after re-soldering.
5. Verified my other stuff is all working properly via hooking it up to my SC-88vl.
