DScaler 4.2.3a
Reply 20 of 41, by elianda
redfox you are the first asking for the source.
I have uploaded it to: ftp://retronn.de/dscaler_fixed/DScaler423a_src.zip
I have just packed together my dev folder, so no fancy cleanup of the code.
It might be a good idea to put it e.g. on github if you also work on it?
As for new files: The filter in plugins called OldGame2 is new.
Youtube Channel
Reply 21 of 41, by Falcosoft
redfox wrote:
I need to do more modifications, since DSC does not recognize current hardware audio mixer lines.
As a result, it is unable to disable the line-in playback automatically, ...
If your are using a Vista+ Windows OS (7/8/10) you will not fix this problem easily since this is not a problem of Dscaler but the OS. The last Windows OS that exposed the real hardware audio mixer lines through the Win32 mixer API was WinXP. So a more easy fix is to use Dscaler in WinXP compatibility mode or use HardwareAudioMixer compatibility shim. More info:
indirect sound
Website, Youtube
VST Midi Driver Midi Mapper
Reply 22 of 41, by redfox
Falcosoft: Thanks a lot for the hint! Setting DSC to WinXP compatibility mode really helped and allowed to use individual mixer lines again.
elianda: Please, could you add an option to disable deinterlacing completely? I think it would be an interesting option for progressive video sources.
Reply 23 of 41, by elianda
redfox: You mean the current option as described in my changelog does not work on your side?
DScaler is mainly a tool for interlaced sources, so progressive support was broken on various places in the code. DScaler always defaulted to interlaced.
Now since progressive is working again, the question was to what should DScaler default on startup?
Luckily DShow sources tell it and for the natively supported cards are all interlaced sources (BT878, Philips).
So quoting myself from the first post:
DirectShow Sources that do not give information if they are interlaced or not can now set manually to Frame or Field mode (go to to DShow/Filter Properties/Open the branch of DScaler video renderer/Input/Force Field/Frame Input). When changing to Field mode the Deinterlace mode will also switch from Progressive to the last set Deinterlace mode.
So if your DSHow source reports nothing or wrongly, you can change/overwrite it there.
Field mode -> interlaced, deinterlace filter list available
Frame mode -> progressive, progressive filter list available, which is currently just one entry "progressive"
In the screenshot in DScaler 4.2.3a you can see that the Epiphan VGA2PCI defaults correctly to progressive. And you can see the other branch in the DShow filters with DScalers input filter. If you select that the dialog with the frame/field selection comes up.
Is that what you are looking for?
Youtube Channel
Reply 24 of 41, by redfox
I use the ATI TV Wonder PCI card from 1999 (720x576), which does not support DirectShow, but works with rhe Dscaler driver (BT 878 card).
Currently, I use it for video playback of the Czech DVB-T2 via composite input, which should be progressive (not interlaced). The only deinterlace filters who display the composite video smoothly without stuttering are 2:2 Pulldown (Odd/Even), or Odd/Even scanlines only .. but these ones have problems on fast motion scenes. I would be interested to see, how smooth the playback would be if no deinterlacing could be applied in Dscaler.
Reply 25 of 41, by elianda
Though the BT878 always captures interlaced. If you have a progressive source then all even frames are put to the even lines and off frames to odd lines. One buffer from the BT878 card contains then two frames.
What are you probably looking for is the Oldgame or Oldgame2 deinterlacer which basically splits the fields to progressive frames again (with doubled frame rate).
(In OBS-Studio the same deinterlacing method is called "retro").
Youtube Channel
Reply 26 of 41, by redfox
Elianda, what PCI-E capture cards with dvi/hdmi input and at least 720p resolution would you recommend for Dscaler?
I'd like something better that my old ATI TV Wonder, with DShow and Windosw 7 64 bit support... I have been searching on eBay, but nothing convinced me, the few models I found are either Chinese nonames or too expensive ones...
Thanks.
Reply 27 of 41, by elianda
I use an Epiphan VGA2PCIe and a DVI2PCIe as DirectShow device with DScaler.
Other recommendations for specific applications are discussed in the VGA Capture thread: VGA Capture Thread
Youtube Channel
Reply 28 of 41, by Bellerophon
Elianda -
I don't know from where to begin...
First of all I would like to thank you because you... exist ! 😀
I'm a Laserdisc collector and thanks to your version of DScaler I'm having the best viewing experience ever on my 55" 4K LG TV from my PAL progressive laserdiscs. From Syntek STK1160 USB.
(NTSC playback in progress due to hardware incompatibility).
Once I found this website, I took my old desktop pc from hybernation and started testing the 3 capture devices I have.
1. Leadtek WinFast TV2000 XP Expert PCI. 2D Comb Filter. CX238801 Chip.
2. Leadtek Winfast PVR3000 DELUXE PCI. 3D Comb Filter + 3D Noise Reduction. Notorious NEC D64015 Chip.
3. EasyCap Syntek STK1160 USB . 2D Comb Filter. Philips SAA7115H Chip.
4. DIAMOND RX507 TV Wonder HD 750 PCIe. 3D Comb Filter. 12bit A/D (on the way).
For NTSC playback I have plugged the TV2000 XP Expert. As you already mentioned, only Interlace mode with this chip, so I can't test the power of the hardware on progressive PAL Laserdiscs. NTSC is very good + CC subtitles (!) but not outstanding compared to native PAL compatibility.
Unfortunately I couldn't test due to complete incompatibility the PVR3000 Deluxe in any mode, Interlace / Progressive.
Because of the very advanced 3D Y/C seperation the NEC Chip offers, is it possible to make this card work on both modes Interlace/Progressive on Dscaler ?
Also can we hope for an Android / CoreElec / Kodi version of Dscaler ? 😀
It would have been great if we could plug the Syntek STK1160 USB in a Beelink GT King let's say and create a powerful, 100% silent and low power consumption A/D video scaling device..!
Thanks again for creating this miracle.
Best regards.
Reply 29 of 41, by elianda
First of all I just did a a few small contributions to the already existing DScaler project with changes that adressed some of my own points.
Though, it is good to hear that it works good for your application too.
PVR3000 Deluxe:
It mainly depends what driver API the card offers. DScaler supports DirectShow and a few older chipsets natively.
Versions for other OS:
Since there is no current development team for DScaler this is out of question.
DScaler was started when Windows 9x was used and the code was written for a lot (nowadays) outdated interfaces.
More senseful would be to start a new application that uses modern interfaces and also supports e.g. FreeSync.
Youtube Channel
Reply 30 of 41, by Bellerophon
These small contributions you've made simply make DScaler work with LD scaling / Deinterlacing like expensive standalone machines, while all other versions don't.
PVR3000 Deluxe
I have both WinXP 32bit and Win7 64bit installed on my PC.
PVR3000 Deluxe is fully compatible with XP while I would say is semi compatible with Win7 64bit due to unofficial drivers;
I don't know if this card supports DShow, I don't think so.
Is it possible for you to try and make this card work with your DScaler version ?
I'm willing to donate of course for your time 😀
I get your point but who can start a new app from scratch capable of using all modern interfaces and including all the goodies from your version..?
Best regards
Reply 31 of 41, by anakin94
@elianda
Thank you for your work.
I really want to use your version, because with it i can use the D3D and Progressive Scan output.
But i have one problem.
With version 4.2.3a i can't record anymore.
It only creates a 512 KB AVI file.
When i switch back to 4.2.3 it's working fine.
Tested on Win7 32 and 64 Bit.
And i have a suggestion.
Is it possible that you can add an option to record in a MKV container file?
Enhanced for Matrox Mystique
Reply 32 of 41, by elianda
Hmm, I have not touched the video recording part, but maybe progressive output somehow interfers with that.
I have to look into this.
What would be the advantages for capturing with DScaler when going from AVI to MKV?
The only thing I can imagine is writing the DAR to the container.
Youtube Channel
Reply 33 of 41, by anakin94
Thank you for your reply.
If i capture with the x264vfw codec to AVI it works fine.
But when i play the file in Windows Media Player or VLC i get every ~5 seconds artefacts.
When i remux the AVI file to a MKV file, then this will not happen.
Here is a screenshots, left is the original AVI file and on the right is the MKV remux.
The attachment DScaler_AVI_MKV.jpg is no longer available
With other codes it works without problems.
This is not a must have, but this would be super for the H.264 codec.
Reply 34 of 41, by marisol
Hello, i use windows 10 64bit
i have pci tv tuner
philips SAA713X hybrid capture device
with hardware id: ven_1131 dev_7134
but every time i open dscaler this don't recognize my pci card,
i have to select uknow and audio source
and after yes i see image and can capture
but i have to do this every time i open dscaler
this is what i see
The attachment asas.JPG is no longer available
any way to add my model to dscaler
thanks
Reply 35 of 41, by darry
marisol wrote on 2021-05-08, 14:20:
Hello, i use windows 10 64bit i have pci tv tuner philips SAA713X hybrid capture device with hardware id: ven_1131 dev_7134 […]
i have pci tv tuner
this is what i see
thanks
I believe that you can add it yourself by modifying the SAA713xCards.ini file in the program's directory . Instructions are provided at the beginning of the file .
Reply 36 of 41, by marisol
this is SAA713xCards.ini , but don't understand how which change
Spoiler
; $Id: SAA713xCards.ini,v 1.19 2007-08-23 14:44:44 dosx86 Exp $
; SAA713x card list.
; ***** Defining a card: *****
; Each card in this list is defined in a single ``section''. A section starts
; with the card name between square brackets ([ ]) and continues until another
; card is named in the same manner. Here is an outline of the data that may
; be contained in each section:
; [<card name>]
; DeviceID = <device id = 0x7130, 0x7134>
; DefaultTuner = <tuner = see below for complete list of tuner>
; AudioCrystal = <audio crystal = none, 32MHz, 24MHz>
; GPIOMask = <gpio mask>
; AutoDetectID = <id1>, <id2>, <id3>
; Input ( <input name>, <input type = tuner, composite, svideo, ccir, radio> )
; VideoPin = <video pin = 0 .. 4>
; AudioPin = <audio pin = none, line1, line2, dac>
; GPIOSet( <bits>, <mask>)
; Final ()
; VideoPin = <video pin>
; UseTDA9887 ()
; SetModes ( <format1> ) = { <demodulation>, <outputport>, <takeoverpoint> }
; SetModes ( <format2> ) = { <demodulation>, <outputport>, <takeoverpoint> }
; (Note: The triangular brackets (< >) are not part of values.)
; The 'card name' can be anything but is limited to a maximum of 127
; characters and should not be the same as another card already in this
; file. This name will be what will appears in the user interfaces in
; DScaler.
; 'DeviceID' can be one of 0x7130 or 0x7134 and relates to the type of
; chip the card has. Cards with a SAA7134 chip should use 0x7134, while the
; other should be used by cards with a SAA7130 chip. Only cards in this file
; with a matching 'DeviceID' to that of the card in the computer will show
; up in the cards selection dialog in DSCaler. Specifying the wrong device ID
; may lead to unexpected results because code paths specific to certain chip
; type is chosen by the value specified here. (Use RegSpy to find out the
; correct value. See below.)
; 'DefaultTuner' is the tuner that will be chosen initially for a card and
; when tuner "auto detection" is used. It should be set to the type of tuner
; on the card. The numeric value of tuners can also be used. See the bottom
; of this file for the complete list of tuners. (RegSpy cannot be used to find
; out this value.)
; 'GPIOMask' defines the input (1) and output (0) in bits of the GPIO status
; bits provided by the SAA713x chip. (Use RegSpy to find out the correct
; value. See below.)
; 'AudioCrystal' is only used by SAA7134 and should be set to"none" or omitted
; for an SAA7130. Selecting the wrong audio crystal may result in incorrect
Show last 1465 lines
; sound.  (Use RegSpy to find out the correct value.  See below.)
; 'AutoDetectID' is a value that identifies a specific card and allows DScaler
; to automatically choosing the proper card type. Not all cards have an auto
; detect id but cards that do should enter the value here. Note '0x00001131'
; is not a valid auto detect id. It is the default value given by SAA713x when
; a card does not have an auto detect id. It can be entered but will be
; ignored. If more than one card in this file have the same 'AutoDetectID' and
; 'DeviceID' only the first card is chosen. Up to three auto detect ids can be
; entered in a comma and optional space delimited list. This can be useful
; when the same card is distributed under multiple brands with different auto
; detect ids. (Use RegSpy to find out the correct value. See below.)
; 'Input (...)'. Put one of these before the definition of every input.
; 'input name' can be anything but is limited to 63 characters. It is what will
; appear in DScaler's user interfaces.
; 'input type' must be one of the five listed. RegSpy cannot be easily used to
; determine out this value. However, one should almost always know what type an
; input is. Note, for "composite over s-video", use 'composite'. The only
; difference between types 'svideo' and 'composite' is in the way some video
; adjustments are performed by the SAA7134 chip.
; 'VideoPin' can be a number from 0 to 4. Setting the incorrect value will
; affect video display in the way of lacking or incorrect source. -1 can be
; set for no video but it can just as well be omitted for the same effect.
; (Use RegSpy to find out the correct value. See below.)
; 'AudioPin' can be one of the four listed above or numeric values 0 to 2 for
; "line1" to "dac" and -1 for "none". Setting the incorrect value will affect
; audio in the way of lacking or incorrect source audio. However, lack of
; audio can be caused by numerous other problems too. (Use RegSpy to find out
; the correct value. See below.)
; 'GPIOSet (...)'. Put one of these if the input should have an associated GPIO
; setting. The 'bits' and 'mask' values of this setting is be used to perform
; arbitary functions specific to the card and/or manufacturuer. (Use RegSpy to
; find out the correct value. See below.)
; 'Final ()' can be put after defining all inputs in the card, to specify the
; configuration that should be applied to the card before DScaler exits.
; Although 'AudioPin' is listed, this setting it is not currently honoured.
; (Use RegSpy to find out a correct value. See below.)
; 'UseTDA9887 ()':
; Formats: pal-bg, pal-i, pal-dk, pal-mn secam-l, secam-dk,
; ntsc-m, ntsc-jp, radio.
; Modes:
; Carrier = qss/intercarrier
; OutputPort1 = active/inactive
; OutputPort2 = active/inactive
; TakeOverPoint = max, min, default, 0x00 .. 0x1f
; Just 'UseTDA9887 = yes' is also accepted.
; ***** Using RegSpy to determine correct values: *****
; If there are more than one card in the computer, make sure the correct card
; is selected in RegSpy. Using RegSpy involves performing a series of step
; very similar to those listed here:
; http://www.dscaler.org/phpBB/viewtopic.php?t=1055
; Put simply, RegSpy is used to see the value of registers in the TV card while
; it is in use by a program other than DScaler. The procedure involves looking
; at the values while the other program is using each of the inputs on the card
; (or as many of the inputs as you want supposed by DScaler.)
; (The RegSpy file can also be sent to me but it may take some time before I
; can reply to your email.)
; The "other program" is usually the TV viewing program that was supplied with
; the card, but can be any TV program that works with your card. (Obviously
; not Dscaler otherwise it would not be necessary to follow these steps.)
; In the "Hardware" box at the top in RegSpy are the values for 'DeviceID' and
; 'AutoDetectID' (Subsystem ID) that will be correct regardless of whether the
; _other program_ is running or which input it is currently showing.
; The correct value of 'AudioCrystal' should appear in the Registers box beside
; "SAA7134_AUDIO_CLOCK" while the _other program_ is showing any input. If
; different inputs show a different audio clock value, use the one for the tuner
; input. Ignoring the first two digits (left most) in the value shown by
; RegSpy, the value of 187de7 means 32MHz and 200000 means 24MHz. (SAA7130
; cards do not have an audio crystal and should use "none" or omit the setting.)
; The value for 'GPIOMask' is available at the same time 'AudioCrystal' above
; is. Its value is that of SAA7134_GPIO_GPMODE bit masked (bitwise AND) with
; 0x0EFFFFFF and '0x' stuck in front of the result. The value shown by RegSpy
; is in hexadecimal. More often than not, all that is necessary to get the
; correct value is to drop the left most digit and put '0x' in the front.
; e.g. "8018e700" becomes 0x018e700. Unnecessary bits left in the value will
; be internally removed during actual use.
; The rest of the settings are input specific. To work out their values, choose
; an input in the _other program_. For that input, the correct values are:
; - For 'VideoPin', looking at the last digit of "SAA7134_ANALOG_IN_CTRL1".
; If it is between 0 and 4 (inclusive), that digit is used. If it is 6 or 8,
; the value used is 0 and the input is probably s-video. If it is 7 or 9, the
; value used is 1 and the input is probably s-video. Any other value is
; unexpected.
; - For 'AudioPin', looking at the last digit of "SAA7134_ANALOG_IO_SELECT"
; masked (bitwise AND) with 3. If it is between 0 and 2, this digit is used.
; Any other value is unexpected. The conversion to textual representation
; (although this is not necessary) is 0 = "line1", 1 = "line2", 2 = "dac".
; - For 'GPIOSet', 'bits' is the value of "SAA7134_GPIO_GPSTATUS" bit masked
; (bitwise AND) with the value of GPIOMask determined earlier. 'mask' can be
; same as the value of GPIOMask. The value shown by RegSpy is in hexadecimal.
; Some values for 'mask' in the cards already in this file differ from their
; respective GPIOMask values but those are the result of some guesswork by me.
; To get the values pertaining to 'Final()', look for the values in RegSpy after
; the other program_ has exit.
; Report bugs in this documentation, card list or those related to the parsing
; of this configuration file to atnak at users.sourceforge.net.
[Proteus Pro [philips reference design]]
DeviceID = 0x7134
DefaultTuner = philips_pal
AudioCrystal = 32MHz
AutoDetectID = 0x20011131
Input ( "Tuner", tuner )
VideoPin = 1
AudioPin = dac
Input ( "Composite", composite )
VideoPin = 0
AudioPin = line1
[LifeView FlyVideo3000 / Chronos Video Shuttle II]
;Chronos Video Shuttle II (Based on FlyVideo 3000, Stereo)
;Thanks "Velizar Velinov" <veli_velinov2001@ya...>
DeviceID = 0x7134
AudioCrystal = 24MHz
GPIOMask = 0x0018e700
AutoDetectID = 0x01384e42
VideoPin = 1
AudioPin = dac
GPIOSet( 0x0000, 0xE000 )
VideoPin = 3
AudioPin = line2
GPIOSet( 0x4000, 0xE000 )
Input ( "S-Video", svideo )
VideoPin = 0
AudioPin = line2
Input ( "Composite over S-Video", composite )
VideoPin = 0
AudioPin = line2
Input ( "Radio", radio )
AudioPin = line2
GPIOSet( 0x2000, 0xE000 )
Final ()
GPIOSet( 0x8000, 0xE000 )
[LifeView FlyVideo2000 / Chronos Video Shuttle II]
;Chronos Video Shuttle II (Based on FlyVideo 2000)
DeviceID = 0x7130
;Some variations of this card use differnet tuners. E.g. Temic PAL
;a.k.a Snazio TVPVR
DefaultTuner = lg_tapcnew_pal
AutoDetectID = 0x01385168
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
Final ()
[EMPRESS]
;(has TS, i2srate=48000, has CCIR656 video out)
;this comment was added when the card was originally taken
;out of Gerd Knorr's saa7134 v4l2 drivers
DeviceID = 0x7134
AutoDetectID = 0x67521131
VideoPin = 1
AudioPin = line2
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[SKNet Monster TV]
DeviceID = 0x7134
DefaultTuner = philips_mk2_ntsc
AutoDetectID = 0x4e851131
VideoPin = 1
AudioPin = dac
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line2
[Tevion MD 9717]
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 2
AudioPin = line1
VideoPin = 3
AudioPin = line1
VideoPin = 0 ; might req mode 6
AudioPin = line1
AudioPin = line2
[KNC One TV-Station RDS]
DeviceID = 0x7134
DefaultTuner = philips_fm1216me_mk3
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 2
AudioPin = line1
Input ( "Composite 2", composite )
VideoPin = 3
AudioPin = line1
AudioPin = line2
[Terratec Cinergy 400 TV]
DeviceID = 0x7134
AutoDetectID = 0x1142153b
VideoPin = 1
AudioPin = dac
VideoPin = 4
AudioPin = line1
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
[Medion 5044]
DeviceID = 0x7134
GPIOMask = 0x00006000
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
GPIOSet( 0x4000, 0x6000 )
VideoPin = 0
AudioPin = line2
GPIOSet( 0x0000, 0x6000 )
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
[KWORLD KW-TV713XRF / KUROUTO SHIKOU]
;KWORLD KW-TV713XRF (saa7130)
;Thanks "b" <b@ki...>
;this card probably needs GPIO changes but I don't know what they are
DeviceID = 0x7130
DefaultTuner = philips_ntsc
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
[Manli M-TV001]
;Manli M-TV001 (saa7130)
;Thanks "Bedo" Bedo@dscaler.forums
DeviceID = 0x7130
;Should be LG TPI8PSB12P PAL B/G
DefaultTuner = lg_b11d_pal
VideoPin = 3
AudioPin = line2
VideoPin = 1
AudioPin = line1
VideoPin = 0
AudioPin = line1
[PrimeTV 7133]
;PrimeTV 7133 (saa7133)
;Thanks "Shin'ya Yamaguchi" <yamaguchi@no...>
;(This card uses the unsupported saa7133 chip.)
DeviceID = 0x7133
;Should be TCL2002NJ or Philips FI1286 (NTSC M-J)
DefaultTuner = philips_fi1286_ntsc_m_j
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
Final ()
[Terratec Cinergy 600 TV]
;Thanks "Michel de Glace" <mglace@my...>
DeviceID = 0x7134
AutoDetectID = 0x1143153b
VideoPin = 1
AudioPin = dac
VideoPin = 4
AudioPin = line1
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[Medion TV-Tuner 7134 MK2/3]
;Thanks "DavidbowiE" Guest@dscaler.forums
;Thanks "Josef Schneider" <josef@ne...>
DeviceID = 0x7134
AutoDetectID = 0x000316be
UseTDA9887 ()
SetModes ( global ) = { OutputPort2 = active }
;Medion 7134 uses OutputPort2 for audio AGC.
;Thanks "Eddy De Greef" on video4linux-list at redhat dot com
VideoPin = 1
AudioPin = dac
VideoPin = 0
AudioPin = line1
AudioPin = line1
AudioPin = line2
[Typhoon TV-Radio 90031]
;Typhoon TV+Radio (Art.Nr. 90031)
;Thanks "Tom Zoerner" <tomzo@ne...>
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
;MUTE, card has no audio in
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[Manli M-TV002]
;Manli M-TV002 (saa7130)
;Thanks "Patrik Gloncak" <gloncak@ho...>
DeviceID = 0x7130
VideoPin = 3
AudioPin = line2
VideoPin = 1
AudioPin = line1
AudioPin = line1
AudioPin = line2
[V-Gear MyTV SAP PK]
;Thanks "Ken Chung" <kenchunghk2000@ya...>
DeviceID = 0x7134
DefaultTuner = philips_pal_i
GPIOMask = 0x00004400
VideoPin = 1
AudioPin = dac
GPIOSet( 0x0400, 0x4400 )
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
[ASUS TV/FM]
;Thanks "Wolfgang Scholz" <wolfgang.scholz@ka...>
DeviceID = 0x7134
AutoDetectID = 0x48421043
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 4
AudioPin = line2
AudioPin = line2
AudioPin = line2
[Aopen VA1000 Lite2]
;Aopen VA1000 Lite2 (saa7130)
;Thanks "stu" <ausstu@ho...>
DeviceID = 0x7130
GPIOMask = 0x00000060
VideoPin = 0
AudioPin = line1
GPIOSet( 0x0070, 0x40 )
VideoPin = 0
AudioPin = line1
GPIOSet( 0x0070, 0x20 )
VideoPin = 0
AudioPin = line1
[ASK SELECT AS-VCV300/PCI]
;(saa7130)
;Thanks "Tetsuya Takahashi" <tetsu_64k@ze...>
; - may have Videoport
; - may have Transport Stream
DeviceID = 0x7130
AutoDetectID = 0x226e1048
VideoPin = 0
AudioPin = line1
VideoPin = 1
AudioPin = line1
[Medion MD-2819 PC-TV-radio card]
;Thanks "Sanel.B" <vlasenica@ya...>
;Thanks "Mc" <michel.heusinkveld2@wa...>
;Thanks "Ing. Arno Pucher" <eolruin@ch...>
DeviceID = 0x7134
GPIOMask = 0x00040007
AutoDetectID = 0xa70b1461
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
GPIOSet( 0x0006, 0x40007 )
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
GPIOSet( 0x0005, 0x40007 )
Final ()
GPIOSet( 0x0004, 0x40007 )
[FlyVideo FlyView 3100 (no audio)]
;FlyVideo FlyView 3100 (NTSC Version - United States)
;Thanks "Ryan N. Datsko" <MysticWhiteDragon@ho...>
;SAA7133 -- not supported
DeviceID = 0x7133
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
[Pinnacle PCTV Stereo]
;Thanks "Fabio Maione" <maione@ma...>
;Thanks "Dr. Uwe Zettl" <uwe.zettl@t...>
;Thanks "Aristarco" <aristarco@ar...>
;Thanks "Abu Baker" <shaair@g...>
;Thanks "Graham Jest" <GrahamJest@ri...>
;Thanks "Werner Meyer" <werner.meyer@ep...>
;Card uses specialized TDA9887 chip configuration for audio
DeviceID = 0x7134
DefaultTuner = mt2050_pal
AutoDetectID = 0x002b11bd
UseTDA9887 ()
SetModes ( pal-bg ) = { intercarrier }
SetModes ( pal-i ) = { intercarrier }
SetModes ( pal-dk ) = { intercarrier }
; These three were tested. Maybe other formats
; should be intercarrier too. (Default is QSS.)
VideoPin = 3
AudioPin = dac
VideoPin = 1
AudioPin = line2
VideoPin = 0
AudioPin = line2
[AverMedia AverTV Studio 305]
;Thanks "Oeoeeia Aieodee" <sid16@ya...>
DeviceID = 0x7130
AutoDetectID = 0x21151461
UseTDA9887 = yes
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
AudioPin = dac
[Elitegroup EZ-TV]
;Thanks "Arturo Garcia" <argabulk@ho...>
;+ Card "Grandmars PV951P4TF" is same except ID and Tuner chip(?)
; Thanks Kwok Kelvin <kelvin002@ho...>
DeviceID = 0x7134
AutoDetectID = 0x4cb41019
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[ST Lab PCI-TV7130]
;Thanks "Aidan Gill" <schmookoo@ho...>
DeviceID = 0x7130
GPIOMask = 0x00007000
VideoPin = 1
AudioPin = line2
GPIOSet( 0x0000, 0x7000 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x2000, 0x7000 )
AudioPin = line1
Final ()
AudioPin = dac
GPIOSet( 0x3000, 0x7000 )
[Lifeview FlyTV Platinum Gold]
DeviceID = 0x7133
DefaultTuner = philips_tda8275
GPIOMask = 0x0019E700
AutoDetectID = 0x03045168
VideoPin = 1
AudioPin = dac
GPIOSet( 0x16400, 0x0019E700 )
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
Final ()
[Lifeview FlyTV Platinum (no audio)]
;Thanks "Chousw" <chousw@ms...>
DeviceID = 0x7133
AutoDetectID = 0x02145168
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
[Compro VideoMate TV Gold Plus]
;Thanks "Stephen McCormick" <sdmcc@pa...>
DeviceID = 0x7134
GPIOMask = 0x001ce780
AutoDetectID = 0xc200185b
VideoPin = 1
AudioPin = dac
GPIOSet( 0x8080, 0x1CE780 )
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
GPIOSet( 0xC8000, 0x1CE780 )
[Much TV Plus]
;Much TV Plus IT005
;Thanks "Norman Jonas" <normanjonas@ar...>
DeviceID = 0x7134
;Should be LG TPI8PSB02P PAL B/G
VideoPin = 3
AudioPin = dac
VideoPin = 1
AudioPin = line1
AudioPin = line1
AudioPin = line2
[Dazzle My TV]
;Thanks <rockmong@ho...>
;Looks like a FlyVideo 2000 clone (from Korea)
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
[Genius Video Wonder PRO III]
;Thanks Michal Kueera <michalk@my...>
;Looks like another FlyVideo 3000 clone (from Czech Republic)
;Notice this card is a SAA7134 but the DAC appears not used
DeviceID = 0x7134
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
Final ()
[V-Gear MyTV2 Radio]
;V-Gear MyTV2 Radio (saa7130)
;Thanks "Daniel Kutin" <daniel.kutin@os...>
;Another card by vendor 0x0138.
DeviceID = 0x7130
GPIOMask = 0x0000e000
AutoDetectID = 0x013819d0
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
AudioPin = line2
AudioPin = line2
Final ()
AudioPin = dac
[K-Win V-Stream Studio TV Terminator]
;Thanks "Alex Perez" <aperez@st...>
;Thanks Petya Petrova <petya_84bg@ya...>
;This card may use VideoPort, and various TS I/O.
DeviceID = 0x7133
GPIOMask = 0x0038e700
VideoPin = 1
AudioPin = dac
GPIOSet( 0x008000, 0x30E000 )
VideoPin = 3
AudioPin = line1 ; guessed
VideoPin = 0
AudioPin = line2 ; guessed
GPIOSet( 0x208000, 0x30E000 )
Final ()
[Terratec Cinergy 200 TV]
;Thanks "Jan Kuhmann" <jan.kuhmann@we...>
DeviceID = 0x7130
AutoDetectID = 0x1152153b
VideoPin = 1
AudioPin = line2
VideoPin = 4
AudioPin = line1
AudioPin = line1
[Empire PCI TV-Radio LE]
;Thanks "Matteo Azzali" <matte.az@li...>
;This card may have noise problems on audio line1 if set to
;"1.0 Vrms or less". (Configured in Advanced Settings.)
DeviceID = 0x7130
GPIOMask = 0x00004700
VideoPin = 1
AudioPin = line2
GPIOSet( 0x000, 0x700 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x200, 0x700 )
AudioPin = line1
AudioPin = line1
GPIOSet( 0x100, 0x700 )
Final ()
AudioPin = dac
GPIOSet( 0x400, 0x700 )
[AverMedia AverTV Studio 307]
;Thanks "Abramov DA" <a6pamob@ya...>
DeviceID = 0x7134
GPIOMask = 0x0c040007
AutoDetectID = 0x97151461
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
GPIOSet( 0x1, 0x7 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x2, 0x7 )
VideoPin = 0
AudioPin = line1
GPIOSet( 0x2, 0x7 )
AudioPin = line2
GPIOSet( 0x1, 0x7 )
Final ()
GPIOSet( 0x0, 0x7 )
[AverMedia DVD EZMaker PCI]
;Thanks "" <renascent@c...>
DeviceID = 0x7130
GPIOMask = 0x00040003
AutoDetectID = 0x10ff1461
VideoPin = 3
AudioPin = line1
GPIOSet( 0x2, 0x2 )
VideoPin = 0
AudioPin = line1
GPIOSet( 0x2, 0x2 )
[Compro VideoMate TV Gold Plus II]
;Thanks "Ruslan" <ruslan@de...>
;Thanks "Elshin Roman" <roxmail@li...>
; I recieved two RegSpy logs of this card with vastly different
; GPIO status and modes. The first style is very similar to that
; which is used by the non-II "Gold Plus" card also in this file.
; It is the GPIO lines that are commented out.
; This card has a TEA5767 chip at I2C address 0x60 (0xC0) which is
; not the tuner.
; Note that this card has the same auto detect ID as the non-II
; version of this card by the same manufacturer.
DeviceID = 0x7134
;GPIOMask = 0x001ce780
GPIOMask = 0x008c1880
VideoPin = 1
AudioPin = dac
;GPIOSet( 0xC8080, 0x1CE780 )
GPIOSet( 0x800000, 0x8c1880 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x801000, 0x8c1880 )
AudioPin = line1
GPIOSet( 0x800800, 0x8c1880 )
AudioPin = dac
GPIOSet( 0x880000, 0x8c1880 )
Final ()
;GPIOSet( 0xC8000, 0x1CE780 )
GPIOSet( 0x840000, 0x8c1880 )
[FOTOCOM TV ONE XP]
;This card appears to use the DAC audio input even though
;it is a SAA7130 card.
DeviceID = 0x7130
DefaultTuner = tcl_2002n
GPIOMask = 0x00003000
AutoDetectID = 0x23111131
VideoPin = 1
AudioPin = dac
GPIOSet( 0x0000, 0x3000 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x2000, 0x3000 )
AudioPin = line1
Final ()
GPIOSet( 0x3000, 0x3000 )
[Medion MD-42073]
;Thanks "Jeffrey Willemsen" <detox@wa...>
;This card is exactly the same as the "Medion MD-2819"
;card that is also in this file except it doesn't have
;the constant 0x4 bit set in the GPIO. This entry might
;not be necessary.
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
GPIOSet( 0x0002, 0x40003 )
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
GPIOSet( 0x0001, 0x40003 )
Final ()
GPIOSet( 0x0000, 0x40003 )
[V-Stream Xpert-TV PVR-7134]
;Thanks "Adam Kodish" <adam.kodish@nt...>
DeviceID = 0x7134
GPIOMask = 0x0700
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
[Terratec Cinergy 400 Mobile]
;Thanks "Kurt Edegger" <news_tmp1@ed...>
; This card does not have a loopback cable and relies
; on DMA for audio which is not supported.
DeviceID = 0x7133
DefaultTuner = alps_tsbe5_pal
GPIOMask = 0x001ce700
AutoDetectID = 0x1162153b
VideoPin = 1
AudioPin = dac
GPIOSet( 0x002000, 0x1ce700 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x042000, 0x1ce700 )
VideoPin = 1 ; 1 for mode 9
AudioPin = line1
Final ()
[Asus 7131D]
;Thanks "Keld Damsbo" <keld@dam...>
DeviceID = 0x7133
GPIOMask = 0x0200000
AutoDetectID = 0x48621043
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
Input ( "CCIR656", ccir )
VideoPin = 2
AudioPin = line2
AudioPin = line2
[ASUS TV-FM 7135 Silicon]
DeviceID = 0x7133
AutoDetectID = 0x48451043
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
[MSI TV@nywhere Plus]
DeviceID = 0x7133
GPIOMask = 0x39E700
AutoDetectID = 0x62311462
Input ("Tuner", tuner)
VideoPin = 1
AudioPin = line1
GPIOSet(0x16400, 0x39E700)
Input ("Composite", composite)
VideoPin = 3
AudioPin = line1
Input ("S-Video", svideo)
VideoPin = 0
AudioPin = line1
Final ()
[MSI TV@nywhere Pro (Pal)]
;Thanks "captain-shiny" from Forum
DeviceID = 0x7134
DefaultTuner = tena_9533_di
GPIOMask = 0x700
AutoDetectID = 0x88031462
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
; ***** Tuner list: (as at July 2005) *****
; auto -2
; setup -1
; absent 0
; philips_pal_i 1
; philips_ntsc 2
; philips_secam 3
; philips_pal 4
; temic_4002fh5_pal 5
; temic_4032fy5_ntsc 6
; temic_4062fy5_pal_i 7
; temic_4036fy5_ntsc 8
; alps_tsbh1_ntsc 9
; alps_tsbe1_pal 10
; alps_tsbb5_pal_i 11
; alps_tsbe5_pal 12
; alps_tsbc5_pal 13
; temic_4006fh5_pal 14
; philips_1236d_ntsc_input1 15
; philips_1236d_ntsc_input2 16
; alps_tsch6_ntsc 17
; temic_4016fy5_pal 18
; philips_mk2_ntsc 19
; temic_4066fy5_pal_i 20
; temic_4006fn5_pal 21
; temic_4009fr5_pal 22
; temic_4039fr5_ntsc 23
; temic_4046fm5_multi 24
; philips_pal_dk 25
; philips_multi 26
; lg_i001d_pal_i 27
; lg_i701d_pal_i 28
; lg_r01f_ntsc 29
; lg_b01d_pal 30
; lg_b11d_pal 31
; temic_4009fn5_pal 32
; mt2032 33
; sharp_2u5jf5540_ntsc 34
; lg_tapch701p_ntsc 35
; samsung_pal_tcpm9091pd27 36
; temic_4106fh5 37
; temic_4012fy5 38
; temic_4136fy5 39
; lg_tapcnew_pal 40
; philips_fm1216me_mk3 41
; lg_tapcnew_ntsc 42
; mt2032_pal 43
; philips_fi1286_ntsc_m_j 44
; mt2050 45
; mt2050_pal 46
; philips_4in1 47
; tcl_2002n 48
; hitachi_ntsc 49
; philips_pal_mk 50
; philips_fm1236_mk3 51
; lg_ntsc_tape 52
; tnf_8831bgff 53
; philips_fm1256_ih3 54
; philips_fq1286 55
; lg_pal_tape 56
; philips_fq1216ame_mk4 57
; philips_fq1236a_mk4 58
; philips_tda8275 59
; ymec_tvf_8531mf 60
; ymec_tvf_5533mf 61
; tena_9533_di 62
; philips_fmd1216me_mk3 63
Reply 37 of 41, by darry
marisol wrote on 2021-05-08, 17:16:
Spoiler
; [<card name>]
; Final ()
; UseTDA9887 ()
; DScaler.
; out this value.)
; 'UseTDA9887 ()':
; Modes:
; unexpected.
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 0
AudioPin = line1
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
Final ()
DeviceID = 0x7130
;a.k.a Snazio TVPVR
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
Final ()
[EMPRESS]
DeviceID = 0x7134
VideoPin = 1
AudioPin = line2
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[SKNet Monster TV]
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line2
[Tevion MD 9717]
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 2
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line2
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 2
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line2
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 4
AudioPin = line1
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
[Medion 5044]
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 0
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
[Manli M-TV001]
DeviceID = 0x7130
VideoPin = 3
AudioPin = line2
VideoPin = 1
AudioPin = line1
VideoPin = 0
AudioPin = line1
[PrimeTV 7133]
DeviceID = 0x7133
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
Final ()
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 4
AudioPin = line1
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
DeviceID = 0x7134
UseTDA9887 ()
VideoPin = 1
AudioPin = dac
VideoPin = 0
AudioPin = line1
AudioPin = line1
AudioPin = line2
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[Manli M-TV002]
DeviceID = 0x7130
VideoPin = 3
AudioPin = line2
VideoPin = 1
AudioPin = line1
AudioPin = line1
AudioPin = line2
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
[ASUS TV/FM]
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 4
AudioPin = line2
AudioPin = line2
AudioPin = line2
DeviceID = 0x7130
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
VideoPin = 0
AudioPin = line1
;(saa7130)
DeviceID = 0x7130
VideoPin = 0
AudioPin = line1
VideoPin = 1
AudioPin = line1
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
DeviceID = 0x7133
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
DeviceID = 0x7134
UseTDA9887 ()
VideoPin = 3
AudioPin = dac
VideoPin = 1
AudioPin = line2
VideoPin = 0
AudioPin = line2
DeviceID = 0x7130
UseTDA9887 = yes
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
AudioPin = dac
[Elitegroup EZ-TV]
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
AudioPin = line2
[ST Lab PCI-TV7130]
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
AudioPin = dac
DeviceID = 0x7133
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
Final ()
DeviceID = 0x7133
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
[Much TV Plus]
;Much TV Plus IT005
DeviceID = 0x7134
VideoPin = 3
AudioPin = dac
VideoPin = 1
AudioPin = line1
AudioPin = line1
AudioPin = line2
[Dazzle My TV]
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
DeviceID = 0x7134
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
Final ()
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line2
AudioPin = line2
AudioPin = line2
Final ()
AudioPin = dac
DeviceID = 0x7133
VideoPin = 1
AudioPin = dac
VideoPin = 3
VideoPin = 0
Final ()
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 4
AudioPin = line1
AudioPin = line1
DeviceID = 0x7130
VideoPin = 1
AudioPin = line2
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
AudioPin = dac
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
GPIOSet( 0x1, 0x7 )
VideoPin = 3
AudioPin = line1
GPIOSet( 0x2, 0x7 )
VideoPin = 0
AudioPin = line1
GPIOSet( 0x2, 0x7 )
AudioPin = line2
GPIOSet( 0x1, 0x7 )
Final ()
GPIOSet( 0x0, 0x7 )
DeviceID = 0x7130
VideoPin = 3
AudioPin = line1
GPIOSet( 0x2, 0x2 )
VideoPin = 0
AudioPin = line1
GPIOSet( 0x2, 0x2 )
; not the tuner.
DeviceID = 0x7134
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = dac
Final ()
[FOTOCOM TV ONE XP]
DeviceID = 0x7130
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
[Medion MD-42073]
;not be necessary.
DeviceID = 0x7134
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
DeviceID = 0x7134
GPIOMask = 0x0700
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
AudioPin = line1
Final ()
DeviceID = 0x7133
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
AudioPin = line1
Final ()
[Asus 7131D]
DeviceID = 0x7133
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
VideoPin = 2
AudioPin = line2
AudioPin = line2
DeviceID = 0x7133
UseTDA9887 = yes
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line2
VideoPin = 0
AudioPin = line2
AudioPin = line2
DeviceID = 0x7133
GPIOMask = 0x39E700
VideoPin = 1
AudioPin = line1
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
Final ()
DeviceID = 0x7134
GPIOMask = 0x700
VideoPin = 1
AudioPin = dac
VideoPin = 3
AudioPin = line1
VideoPin = 0
AudioPin = line1
; auto -2
; setup -1
; absent 0
; philips_pal_i 1
; philips_ntsc 2
; philips_secam 3
; philips_pal 4
; alps_tsbh1_ntsc 9
; alps_tsbe1_pal 10
; alps_tsbe5_pal 12
; alps_tsbc5_pal 13
; philips_pal_dk 25
; philips_multi 26
; lg_i001d_pal_i 27
; lg_i701d_pal_i 28
; lg_r01f_ntsc 29
; lg_b01d_pal 30
; lg_b11d_pal 31
; mt2032 33
; temic_4106fh5 37
; temic_4012fy5 38
; temic_4136fy5 39
; lg_tapcnew_pal 40
; mt2032_pal 43
; mt2050 45
; mt2050_pal 46
; philips_4in1 47
; tcl_2002n 48
; hitachi_ntsc 49
; philips_pal_mk 50
; lg_ntsc_tape 52
; tnf_8831bgff 53
; philips_fq1286 55
; lg_pal_tape 56
; tena_9533_di 62
If everything works for you with default settings and you do not want/need to bother with finding proper input, GPI, etc values , but just want to get rid of that detection screen, you could try to insert
[Unknown]
DeviceID = 0x7134
AutoDetectID = 0x712817DE
starting at line 197 in the file .
No guarantees, best of luck .
Reply 38 of 41, by Sphere0161
Hello,
I have a PCI Pinnacle pctv with a BT848 chip, my BIOS is in Legacy mode and I am using Windows 10 x64.
DScaler 4.2.3.a is able to recognise I have got a Bt848 video decoder.
Then DScaler shows a message saying: Error Cant use overlay. File OverlayOutput.cpp Line 1340, ans ask to try directX, saying yes, makes the whole computer freeze. I have the directplay compatibility layer installed.
All this happen if I executed it with (or without) compatibility with Windows XP SP3. I am out of ideas. So if someone has another idea to try, please let me know.
PS: I post in this old topic because it is the only useful thing that appears when looking for how to use a Bt848 in modern Windows. I can open a new topic if needed.
Reply 39 of 41, by Falcosoft
Sphere0161 wrote on 2022-12-29, 10:05:
Hello, I have a PCI Pinnacle pctv with a BT848 chip, my BIOS is in Legacy mode and I am using Windows 10 x64. […]
Hello,
This problem is not Dscaler specific. Since Windows 8 you cannot use HW Overlays required by DScaler without setting specific keys in registry. In this independent topic you can get more info about potential solutions:
Re: Hardware overlay support
Website, Youtube
