First post, by Pee wee
Pee wee
Offline
Hi guys,
I hope you are all well.
Pls, I needs you to give me a hand with RetroArch. I think the "DOSBox SVN" core does not have support the Roland MT-32. In any case, I would like to know how I can enable the "Gravis UltraSound". I have the "ULTRASND" folder. I think it should be put in "C:\ULTRASND" or inside the game folder. But I think that is not enough. I think a .bat or .conf file needs to be created in addition. I'm new and don't understand much about command lines. Any example?
I would appreciate any help.
MANY THANKS IN ADVANCE.
