HDD JVC pinout
First post, by wulp
Hello,
I found this HDD in an old portable (BMx 2100). The connection is a 44 pin IDE.
The power is apparently integrated in the flatcable.
I can't find anything about this HDD.
Does anyone has an idea?
Thanks!
Reply 1 of 2, by weedeewee
44 pin ide pinout can be easily found by googling for it.
it's actually identical to normal IDE, though instead of 2.54mm pitch it's 2mm pitch ie distance between pins, with an added 4 pins for gnd & 5v power.
https://web.archive.org/web/20041222200600if_ … h/2000/1900.htm a nice 21MB drive.
Do not ask Why !
Reply 2 of 2, by wulp
Oh great!
I googled a long time, but apparently not with the correct search term ...
Thanks!
