First post, by caltrop
The README is a bit vague as anything else I found.
This right?
serial1=directserial realport:ttyUSB0
How do you configure it to COM1?
I went thru !@#$% getting it enabled in Linux.
lsusb
Bus 003 Device 003: ID 0c45:6321 Microdia
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 2478:2008 Tripp-Lite U209-000-R Serial Port
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
sudo modprobe usbserial vendor=0x2748 product=0x2008
dmesg (exerpt)
[ 4249.477757] usb 4-3: reset full-speed USB device number 2 using ohci-pci
[ 4249.682348] pl2303 4-3:1.0: pl2303 converter detected
[ 4249.704530] usb 4-3: pl2303 converter now attached to ttyUSB0
Reply 1 of 11, by caltrop
Well I guess no one knew the answer.
So here's the FIX!
lsusb exerpt: Bus 004 Device 002: ID 2478:2008 Tripp-Lite U209-000-R Serial Port
dmesg exerpt: USB Serial support registered for pl2303
dosbox: serial1=directserial realport:ttyUSB0
Everything loads but it is not working.
Found a fix... 😀
$ sudo chmod 666 /dev/ttyUSB0
But I fear that I will have to do this everytime I boot up the system &
plug the USB Serial Adapter in...
Now I can use the USB Serial Port with DOSBox and communicate with my venerable HP48GX.
Everytime I do something with another OS in Linux I... 😠
Reply 2 of 11, by dougdahl
(This should only help with the sudo chmod 666 /dev/ttyUSB0 part)
At https://forums.linuxmint.com/viewtopic.php?t=135914
they mention that if you want to have access to that /dev file as a user after a reboot you need to run
sudo adduser (your user name e.g USER in my case) dialout
as that will give you as a user access to the serial ports.
Reply 3 of 11, by gdjacobs
To be a little more general, double check the group ownership of the device node using 'ls -l', then ensure your user is added to the appropriate group as above.
Reply 4 of 11, by caltrop
this is also in the attachment:
a bit problematic with some programs I am using
one program works with another or both separately
one can be a shell to the other
PDL -> PDLKERM
when one is run the other no longer can access the serial adapter
one requires the 'mode' command to configure the port 'com1'
a restart is required to get one or the other working
    DOSBox_PDL.zip
    1.17 MiB
    89 downloads
    additional issues
Reply 5 of 11, by caltrop
everything is working now
the 'chmod' alone fixed things
but there is more as mentioned in the previous post
this all relates to the HP48GX & the DOS PDL Programmers Utility
and KERMIT
this has been a fun adventure as are all my Linux endeavours
Reply 8 of 11, by caltrop
here we go again...
it's 2021 and I now have Mint Mate 20.1 and...
the USB Serial Adapter I was using in Mint 18.1 is NOT working in 20.1, it was a headache back then and worse now
and the Bluetooth is also having issues but that's not DOSBox
what is it with Linux Mint and adapters?
I'll post more when I get back on the computer and WiFi...
but so far it is a MYSTERY...🤔
Reply 9 of 11, by _Rob
It is possible that the dialup group no longer exists in a modern distribution. You may want to do a search for "udev permissions for ttyUSB0" on how to automatically give permissions when the device is plugged in.
e.g. , https://superuser.com/questions/431843/config … for-dev-ttyusb0
Another way is to check the permissions of the device.
ls -l /dev/ttyUSB0
Reply 10 of 11, by caltrop
here we are in Mint Mate 20.1 & DOSBox 0.74-3 reported DOS 6.22
and Serial support is still spotty
sometimes it works, most times not
DOSBox
serial2=directserial realport:ttyUSB1
serial3=disabled
serial4=disabled
USB Serial Adapters
Bus 001 Device 010: ID 2478:2008 Tripp-Lite U209-000-R Serial Port
Bus 001 Device 007: ID 2478:2008 Tripp-Lite U209-000-R Serial Port
/dev/ttyUSB0, UART: 16654, Port: 0x0000, IRQ: 0
/dev/ttyUSB1, UART: 16654, Port: 0x0000, IRQ: 0
unfortunately the Linux System will not alow configuration of the adapters
Sun May 16 07:18:41
$ setserial /dev/ttyUSB0 irq 4
Cannot set serial info: Inappropriate ioctl for device
Reply 11 of 11, by _Rob
@caltrop I'm not talking about running setserial. I'm talking about the permissions of the /dev/ttyUSB0 device.
But speaking of setserial, what does this output:
setserial -G /dev/ttyUSB0
Can you run the following command and provide the output:
ls -l /dev/ttyUSB*
I don't have any USB serial adapters myself, but on my Fedora installation there is still a "dialout" group, which should also exist on your Linux Mint installation. And I suspect that if I where to add my user to that group, I could use any supported serial device. e.g. something along the lines of:
sudo usermod -a -G dialout caltrop
You can check which groups your user is a member of by running:
groups
