Fixing floppy drives ?
First post, by SETBLASTER
i got an old system that was kept untouched for many years.
tried to read a brand new floppy disk and it worked
then copied files to the floppy disk and it worked also
then tried to run a program install from the floppy disk and it failed at some percentage of the installation
after that. the floppy drive refused to read the floppy and any other floppies i got
what kind of repair can be done to save floppy drives besides using the floppy disk cleaner with alcohol?
a recap of all electrolitic capacitors on the pcb is enough?
its not the first time that some drives died or refused to read or write.
Reply 1 of 2, by Caluser2000
First thing I'd do is clean the heads.
Reply 2 of 2, by Horun
Caluser2000 wrote on 2021-05-21, 00:40:
Yes ! While cleaning heads: use a little ISO alc on a Q-Tip/cotton swap and touch up the rails, stepper screw and all places that are lubricated where you see old grease,
then apply a slight amount of new light weight white grease with a tooth pick to those areas.
Set the BIOS to do floppy seeks and do a bunch reboots so the heads get moved, do that a dozen times and try to read disk agian.
