First post, by Syntaxomat
I am on an Android tablet with the Magic Dosbox app installed and i want to know if it is true that DOSBOX emulate the 16 bit Big real mode only in Magic DOSBOX, or also in other DOSBOX versions for Windows/Linux too.
Because i can properly write into the linear framebuffer in hex c0000000 mashine s3-chip without using an EMS or XMS function. Both EMS and XMS are set to true in the config file of Magic DOSBOX. I remember in MS DOS i have to REM the emm386.exe-driver in the config.sys file for to swith into the 16 bit Big RM.
