First post, by tomcattech
Doing some overall upgrades on my DX8 Win98SE rig and I'm wondering if there is any reason to go from GeForce2 to 3 or 4.
My current 98 games run great on my GeForce2 GTS\32 and I have a Pro\64 inbound.
No driver issues, incompatibilities, jaggies, weird graphics.... pretty much the sweet spot.
However, I'm wondering if I'm missing some horsepower on the GPU side and am wondering how much of a dice roll I'm making by going to GeForce 3 or 4 with new architecture, unknown drivers, etc....
Any thoughts?
Reply 1 of 5, by gerry
tomcattech wrote on 2021-05-26, 14:36:
Doing some overall upgrades on my DX8 Win98SE rig and I'm wondering if there is any reason to go from GeForce2 to 3 or 4. […]
Any thoughts?
If you are happy then leave it as is, especially as you have no problems at all
I have a 98se machine (Duron 800) with geforce 4 mx440, newer but in practice about the same performance and it does all i want on that machine - it may be worth considering if you had a 3 or 4 Ti or something notably more powerful
I suppose you could always test it and then go back to the trusty gts if not happy
Reply 2 of 5, by Jackhead
most compatible what i test are 3dfx boards. The GeForce 2,3.. gives me some hardware conflicts (my setup). So i run a Geforce 256 for any up to year 2000 games. Anyway i would say a 1GHz P3 system with a Voodoo5500 if you want max out Win98se on one way, sure there other options..
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 3 of 5, by nd22
Please put exact rig specifications so we all know what you are talking about! The most powerful 98Se GPU with native support would be a geforce 6800 ultra/radeon X850 XT PE but those are stupidly expensive! Recommended only if you want to play at 1600*1200 max settings when a geforce2 ultra would choke!
In my testing with Windows 9X games I found that the sweet-spot is something along the lines of a Pentium 3 + geforce 3/4 combo however I have limited experience with 9X!
Reply 4 of 5, by tomcattech
System Specs
Win 98 SE
Pentium III Socket 370 1000MHz Coppermine \ 133 MHz FSB \ 256k Cache
512 MBytes SDRAM
Motherboard: Tyan S2507T \ Tiger 230T
NVidia GEForce2 GTS / 4x AGP - Soon to be GeForce2 Pro / 4x AGP
Reply 5 of 5, by nd22
As I understand you got a dual CPU system! I would use Windows 2000 on that machine because 98SE can only use 1 CPU!
I also have several dual CPU systems: On my Abit VP6 with Pentium 3 1000mhz and 2gb of ram I use geforce3 ti 500 and i t runs just fine; all 2000 -2001 games run at the highest settings, only the resolution needs to drop down in order to achieve 60 fps - this proves that the CPU is not limiting the video card!
I should mention that I also use the same video card on my Tualatin 1400/Abit ST6/512mb/Windows ME and it is perfectly suited for 2000-2001 games - performance is again limited by the video card and not by the CPU!
However because it is considered a collector's item geforce3 ti 500 is very expensive if you manage to find one! I would recommend a geforce4 ti 4200 - cheap, easy to find and better performance than ti 500.
