Reply 1180 of 2766, by Falcosoft
- l33t
FE345 wrote on 2021-05-14, 16:16:can sombody help me im hearing weird vibrato a like in sc 88 mod is it my mid file or something else ? (this happend when i use all sf2 file not happend in midi mapper and vst)
This is a Bassmidi problem, you can find more info about it here:
https://www.un4seen.com/forum/?topic=18625.ms … 34939#msg134939
In the topic referred above you can find Bassmidi versions that cure the problem somewhat. But as for me I suggest to use the older version that can be found in older versions of FSMP:
https://falcosoft.hu/midiplayer_57.zip
https://falcosoft.hu/midiplayer_57_x64.zip
PS: Soon I will release a new version of FSMP with older versions of Bass/Bassmidi libraries since I do not like the way this and other problems are handled by new versions...
