First post, by TusockyThree68
- Newbie
I am running Windows98 and I was trying to run some games from DOS mode (via the start menu -> shit down -> reboot into DOS mode) and one says it needs more conventional memory. So, I tried to do some memory management and from some of the places I was reading, you can force programs to run in upper memory by using LH and load drivers in upper memory by using DEVICEHIGH. But when I run MEM it shows me that I have 0 kb of upper memory. Also, using those DEVICEHIGH and LH keywords did nothing to change what was where in memory. I have attached some pictures of my config.sys, autoexec.bat, and my results of mem and mem /c. What could be causing me to not show any upper memory? If I truly don't have any upper memory then what can be done to manage my conventional memory better?
