1; A TSR for MS-DOS - By: Peter Swinkels, ***2021*** 2 3; Retrieves interrupt 0x08's vector. 4CLI 5MOV AH, 0x35 6MOV AL, 0x08 7INT 0x21 8 9; Places the retrieved vector at another interrupt. 10MOV DX, BX 11PUSH ES 12POP DS 13MOV AH, 0x25 14MOV AL, 0xC8 15INT 0x21 16 17; Places this TSR at interrupt 0x08. 18PUSH CS 19POP DS 20MOV DX, TSR 21MOV AH, 0x25 22MOV AL, 0x08 23INT 0x21 24 25; Terminates and stays resident. 26MOV AH, 0x31 27MOV AL, 0x00 28MOV DX, 0x00FF 29INT 0x21 30 31TSR: 32; Disables hardware interrupts. 33CLI 34 35; Saves the registers. 36PUSHA 37PUSH DS 38 39; Disables Num Lock. 40MOV AX, 0x40 41MOV DS, AX 42MOV BX, 0x17 43MOV AX, [BX] 44AND AX, 0x6F 45MOV [BX], AX 46 47; Restores the registers. 48POP DS 49POPA 50 51; Calls the redirected interrupt. 52INT 0xC8 53 54; Sends an End-Of Interrupt signal to the 8259 interrupt controller. 55PUSH AX 56MOV AL, 0x20 57OUT 0x20, AL 58POP AX 59 60; Returns.
…Show last 3 lines
61STI 62IRET
I see no relevant differences with what the video instructed to write and everything appears to make sense. Did I screw something up or doesn't DOSBox support this kind of TSR?
It appears you put the replacement INT 8 handler on vector C8h as well, typo in line 22. Also, your handler need not acknowledge the interrupt, as the original one will do that.
I wonder which assembler you're using, because many DOS-era assemblers recognize the NNh form of hexadecimal, but not the 0xNN form.
Some general points: your use of CLI/STI in the interrupt handler is unnecessary because interrupts are always disabled when the handler is entered and IRET will restore the interrupt flag to its former state along with the other CPU flags. PUSHA/POPA are excessive, you only need push/pop AX and BX in addition to DS because they are the only registers your handler modifies. For your apparent intention to disable numlock, you need to mask off bit 5 of 40h:17h, but you're also masking 40h:18h entirely (which may indeed cause the keyboard to not work properly) by using a word pointer instead of a byte pointer, so I guess you want:
MOV AL,[BX]
AND AL,0DFh ; mask off bit 5 (numlock mode)
MOV [BX],AL
Lastly, there are debugger builds of DOSBox you can use to analyze what your assembled program is actually doing: DOSBox debugger
The cli at handler entry and the sti at exit don’t do anything useful, and I don’t get the cli at the very beginning. At least do an sti before exiting. Maybe one of the invoked int functions does this implicitly. I don’t remember and did not bother looking it up, but at least it looks strange.
You should pay attention to which type of program binary your assembler of choice is producing (COM or EXE), and if additional things (e.g. ORG 0x100 for COM, stack location for EXE, etc.) are needed for the type produced.
I’ve never used nasm for DOS, so I don’t know how to instruct it to generate a COM. But you are most likely missing the equivalent of "org 100h".
I used tasm and tlink and copied your code into a skeleton from the examples/usrguide directory, replaced all 0x with a "h" suffix, added one "offset" and checked the resulting binary with ndisasm.
Okay, I made a few changes and decided to try to have my TSR display a character instead of modifying the Num Lock status. Code:
1; A TSR for MS-DOS - By: Peter Swinkels, ***2021*** 2ORG 0x0100 3 4; Retrieves interrupt 0x08's vector. 5CLI 6MOV AH, 0x35 7MOV AL, 0x08 8INT 0x21 9 10; Places the retrieved vector at another interrupt. 11MOV DX, BX 12PUSH ES 13POP DS 14MOV AH, 0x25 15MOV AL, 0xC8 16INT 0x21 17 18; Places this TSR at interrupt 0x08. 19PUSH CS 20POP DS 21MOV DX, TSR 22MOV AH, 0x25 23MOV AL, 0x08 24INT 0x21 25 26; Terminates and stays resident. 27MOV AH, 0x31 28MOV AL, 0x00 29MOV DX, 0x00FF 30INT 0x21 31 32TSR: 33; Disables hardware interrupts. 34CLI 35 36; Saves the registers. 37PUSHA 38PUSH DS 39 40; Displays a character. 41MOV DL, 0x21 42MOV AH, 0x02 43INT 0x21 44 45; Restores the registers. 46POP DS 47POPA 48 49; Calls the redirected interrupt. 50INT 0xC8 51 52; Sends an End-Of Interrupt signal to the 8259 interrupt controller. 53PUSH AX 54MOV AL, 0x20 55OUT 0x20, AL 56POP AX 57 58; Returns. 59STI 60IRET
It appears to work now. When I get around to it I am going to see if I can integrate some code I wrote that dumps all conventional memory to a file. That's why I wanted to create a TSR to begin with. Thank you all for your input!
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here: https://github.com/peterswinkels
IMO, TSRs that react to a key press should hook the keyboard IRQ 1 handler (INT 9) because the interrupt only occurs when there is a key press or release. Using the timer IRQ 0 (INT 8) as you have is inefficient and adds unnecessary processing to the system.
Since you're posting in the DOSBox section of the forum, why not just use the DOSBox debugger to dump memory?
I don't like the DOSBox debugger, a lot of steps. Writing my own software may be more work at first, but being able to press a single key to dump all conventional memory is worth it. Yeah, there is room for improvement in what I wrote. When I get around to it I will investigate using other methods.
OTOH using the timer interrupt may be more reliable because most games intercept the keyboard interrupt and never call the original handler, whereas I assume they continue calling the timer interrupt, even if they install their own handler.
EDIT:
Nevermind my earlier question. I figured it out and made the appropriate changes. Thank you for pointing that flaw out. Your earlier comment implied there were several things wrong, which other things need to be fixed as well according to you?
