First post, by Gopher666
- Newbie
Recently I found some fun project:
https://dogemicrosystems.ca/wiki/Dial_up_server
https://dogemicrosystems.ca/wiki/Dial-up_pool
The two is basically the same the least with more modems. It's like having a little R&R dialup setup where you are your own ISP sounds fun.
Definitely a future project for me to build cause I loved the sound of the dialup modems dialing in every day to surf the web 😀
I wonder if someone built this or something like this.
The only 2 things which bothers me in his setup:
-Depends on the ISP-side modems used; the hardware used in this guide can only reach a maximum of 33.6k. Also somewhere he noted that he even needed lower speed due to stability issues I would like to have a nice 56k
-He is using 2 port Linksys PAP2T well I'm sure there are better options for ATAs with multiple ports. Dialup and all this is a dead technology even enterprise grade ATAs should be dirt cheap Today.
Obviously you need 2x ports per 1 single client as the circuit is established between modem->ata port1 -> ata port2 -> modem2
