Bit of an upgrade on my Compaq laptop, I've finally got my SD to IDE adapter working.
Needed to use another computer to install DOS, but after that it was all smooth sailing.
Copied the Windows 3.1 setup files onto the SD Card, and started installing it.
After that, installing the video and pcmcia drivers was a bit tricky, since the driver itself is an extractor program that extracts and copies all the setup files onto a floppy disk, and since the floppy drive doesn't work on the laptop, i've booted up my Windows 98 pc, put the files onto a floppy disk as intended, and then copied them onto the SD card. It's a bit complicated this way, but without a floppy drive this is how you can do it the fast way. And thank god for having a Setup.exe for every drivers, no need to hunt down the .inf files.
One thing I did not set up yet is the driver for the CF to PCMCIA adapter, it shouldn't be hard to find one online.
Finally, I've got this laptop future proofed in terms of storage, and also got 1,2gb more space, since I'm using a 2gb card, the hdd was only 800mb.
I've just need to copy all my programs and games back, good thing I've archived the hdd.
So you think it's really good, yeah? You should try making the bloody thing up; it's a real pain in the arse.
I'm no American.
