Stack segment not present
Reply 40 of 43, by mf2hd
I'll include your and wd's findings in the patch some time (and will also have to fix it up for latest CVS).
I've just added the svga patch.😁
It was compiled without problems and running fine (with the et4000 in settings there is a lot of "green" in all the colors, but this is not a problem for me).
A last little question: the exe is about 15MB, is there any "trick" for mingw to create a "small" output?
_mf2hd_
Reply 41 of 43, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Seems to be a general problem. I have some cad here with the same issue.
1+1=10
Reply 43 of 43, by mf2hd
strip dosbox.exe
2.18MB 😁
Thanks.
