Reply 100 of 138, by Brute389
variable wrote on 2021-03-30, 06:56:
https://drive.google.com/file/d/1WzQr6yMM_TSa … iew?usp=sharing […]
Brute389 wrote on 2021-03-11, 06:20:
variable wrote on 2021-03-09, 22:48:
I have a C1XS recovery disc image. Will upload to archive.org and link you here
I was wrong, sorry! I do have an image of someone's drive out of a C1XS though if you'd like. Probably not much use as from my experience you really need the installers for all of the Sony stuff.
Honestly, I would still take you up on the offer as it is better than nothing! Besides, it would be nice to have something somewhat preconfigured to go off of! I appreciate it.
It's a Macrium Reflect image. Not my drive so can't vouch for its usefulness but all the key parts seem to be there.
Let me know once you've got it, I don't have much space left on my Google drive haha.
I went ahead and grabbed it. Thanks again for the trouble. Is there a way for me to restore the macrium reflect image without hooking up the drive to my modern pc?
Reply 101 of 138, by variable
Brute389 wrote on 2021-03-30, 08:22:
Boot off another disk and restore from there. You should be able to extract the reflect image and make a different format if needed. I would probably just pull the drive - be careful with the hinge caps and ribbon cables!
Reply 102 of 138, by Intel486dx33
I have some Vaio recovery cds and dvds for Win95 and 98 and 2000
But they require a specific model computer.
Anyway to get around this and burn them to a cd that is not model specific ?
Reply 103 of 138, by Aezn
variable wrote on 2020-05-26, 08:29:
cyclone3d wrote on 2020-05-26, 05:01:
variable wrote on 2020-05-26, 01:56:
That would be really awesome, thanks so much! I'll have a rifle through your ftp backup but having an image of the actual discs would be killer
I do have the PCG-C1X restore CDs. The regular C1X came with a 266Mhz CPU and the C1XA came with a Pentium II 400Mhz. I wonder if the restore discs would be the same?
I think it should probably be ok - if you find it I'd really appreciate an upload! I've managed to get images of the restore discs for the C1-XE off someone but it's no good as it's for Japanese Win98 🙁 I've also managed to cobble together most of the essential drivers from various places online but I still can't get the jogwheel, capture button or batteryscope working properly (I'm using the exe's and drivers for another model with some limited success).
When I first got the C1-XA it was all working fine so I removed the hdd to do a backup and managed to corrupt it with a flaky cable. Pain.
hello, i am looking for recovery cds for my sony vaio pcg-c1xa do you have the cds or do you know where i can get them?
Reply 104 of 138, by cyclone3d
I've been collecting the Sony Vaio restore CDs but have not run across any for the PCG-C1Xa.
Your best bet is to just do a clean install of Windows and then install the needed drivers and apps.
I am slowly working on putting together driver packs for the models I own and will post them on archive.org as I complete them.
Here is a live copy of the Sony Vaio ftp - not mine:
http://dose.0wnz.at/ftp.vaio-link.com/
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 105 of 138, by leecher
My guess is, that the PCG-C1XA is very similar to the PCG-C1XN, as I guess: A...Australia, N...New Zealand
There are drivers available for it:
http://sonyvaiodriver.com/page/2/?s=PCG-C1X
Construct valid download URLs like mentioned in my post: Re: Sony ending downloads for anything prior to Windows 7
Reply 106 of 138, by cyclone3d
The bad thing about sonyvaiodriver.com is that sometimes the drivers for the wanted OS are not even listed. And some drivers aren't listed at all for any OS.
I've been having to do trial and error for the driver packs I am working on. I've opened some of the drivers with 7-zip to see if they are what I am needing.
YMF7x4 Guide
Reply 107 of 138, by variable
Intel486dx33 wrote on 2021-04-05, 08:18:
Which models are you after and which models do you have?
Aezn wrote on 2021-04-08, 01:54:
Unfortunately not, I'm after that one as well. As cyclone3d said, you can do a standard Win98 install and then use the Sony installers for the drivers. I've found you really have to install and run the 'Sony Notebook Setup' first *before* any others or their installers will complain or only half work. A lot of the Sony software does hardware checks to ensure it's only running on Sony hardware and it seems to mostly check through that program.
leecher wrote on 2021-04-08, 06:22:
I think XA is for the whole Asia Pacific region (Hong Kong, Australia, NZ etc). I have one and it was originally from a shop in Hong Kong (still has their sticker on it) and I know someone who bought one new in NZ in 2000. But yeah XS (USA), XA (Asia Pacific) & XD (Europe) are all the same hardware (400MHz Pentium II, 12GB hard disk, 64MB memory). XE (Japan) & XN (USA) are both lower spec (266MHz).
The Japanese Win98 drivers are sort of compatible with non-Japanese Win98 but will either have incorrect text in them or just straight up not work.
I made a big spreadsheet of all of the PCG-C1 models. It has some holes in it but is mostly complete. Feel free to have a look here: https://docs.google.com/spreadsheets/d/1wa3Mn … dit?usp=sharing
The Japanese models are easy enough to find info on as Sony Japan still has their original webpages online (highly recommended flashback browsing – https://www.sony.jp/support/vaio/products/pcg/index.html) but most of the other regions I've just pieced together from manuals, old promo material/reviews etc. Sony's Vaio model naming conventions are enough to make you question your sanity... haha
Reply 108 of 138, by EvieSigma
cyclone3d wrote on 2021-04-08, 03:02:
I've been collecting the Sony Vaio restore CDs but have not run across any for the PCG-C1Xa. […]
I've been having a lot of trouble trying to navigate this, where would I find the drivers/applications for a Vaio desktop? I just bought a PCV-2252 off ShopGoodwill.com and it has some front panel video inputs that probably don't work without a Sony driver.
Reply 109 of 138, by cyclone3d
EvieSigma wrote on 2021-04-16, 23:51:
That is the part number. Looks like the actual model number is:
PCV-RS630G
Go here and mouse over the links and you will see the file names you need to get.
http://sonyvaiodriver.com/category/sony-vaio- … rs630g-drivers/
YMF7x4 Guide
Reply 110 of 138, by EvieSigma
cyclone3d wrote on 2021-04-17, 01:01:
That is the part number. Looks like the actual model number is: PCV-RS630G […]
PCV-RS630G
Thanks, these should help! A program like SDIO will help me get the more standard drivers but Vaio-specific stuff would be harder without resources like this.
Reply 111 of 138, by oximinus
Hi, my name is Nelson i'm from Argentina and i like to restore old machines, so i got a vaio PCG-F450 (Pentium 3 500, 9Gb HDD, 128Mb), wich was originally sold with Windows 98 installed on it, this one came with a user installed xp, so i had no oportunity to se what the original software/drivers was (because the xp install didnt have any at all) of course i'm trying to find its original drivers, or original recovery media, or hdd backup or replacement drivers anything will help, so far i been able to clean install windows 98 but could not find much info on it.
I came here seeing a lot of activity trough the forums so seem a nice place to share my help on anything i could too, you can see some of my work here fb.com/RetroLabMDQ where i do frequent posts about restoration repairs and more, thanks in advance!!
Reply 112 of 138, by JonF
Hey guys, I am looking for the below BIOS update files for my PCG-C1MVP/M:
PHA3E0XNDR.EXE
PHA7E03NKM.EXE
I can't find them on the ftp or anywhere. Is there a way to search the ftp? Does anyone happen to have a copy of these files?
Thanks!
Reply 115 of 138, by leecher
But I don't think that you'll find the drivers you are searching for on vaiolink FTP mirror. Look here instead:
C1VP Drivers: http://sonyvaiodriver.com/?s=pcg-c1vp for description of files
https://rebyte.me/de/sony/6002/ for download
C1VP drivers: http://sonyvaiodriver.com/?s=C1MWP+
https://rebyte.me/de/sony/6243/ for download
Reply 116 of 138, by EvieSigma
leecher wrote on 2021-10-16, 14:00:
Why don't you just use http://dose.0wnz.at/ftp.vaio-link.com/ ?
That link seems to go to a bunch of folders with descriptions in German, none of which seem to have anything to do with Vaio computers. I'm trying to find the right BIOS update for a VGC-RB40 desktop and the closest I've found is just a ROM file for a VGC-RB42G, which might not work.
Reply 117 of 138, by leecher
Weird, it seems that the nfs mount point on the server messed up and mounted the wrong share...
Now correct ftp.vaiolink.com got mounted again. I wonder how long it will last.
Reply 118 of 138, by cyclone3d
I just put my copy back up. It is still not fun to try to figure out the correct file names though.
current ftp address is:
windows98se.ddns.net
username : anonymous
No password
YMF7x4 Guide
Reply 119 of 138, by EvieSigma
cyclone3d wrote on 2021-10-17, 21:47:
I just put my copy back up. It is still not fun to try to figure out the correct file names though. […]
No password
Yeah, I have no idea which of the files in the "BIOS" directory are the one I need, or if any of them are, because none of their file names have the ID string of the BIOS in them.
