Reply 39620 of 57297, by Joakim
dionb wrote on 2021-06-27, 14:56:
Worth mentioning what I didn't pick up today, due to being too hung over to check my mail after posting an offer on old hardware […]
Worth mentioning what I didn't pick up today, due to being too hung over to check my mail after posting an offer on old hardware. Offer accepted, but after I didn't respond someone else got lucky.
What did I miss:
- Voodoo 1
- IBM Model M
- Baby AT case with early 486 look about it
- at least 3 small old monitors, probably VGA but not even certain
- a few boxes of other odds & ends which might well have contained more goodness.
Bugger. Could have had all that for very little indeed and have no one other than myself to blame.
Ok often it is the other way around, where you buy something when you're drunk and wake up the next day and wonder why... I heard that this from a friend of a friend, of course... 😉
Reply 39621 of 57297, by Miphee
Well, it wasn't that difficult after all. Intel DX58SO s1366.
Reply 39622 of 57297, by dionb
Joakim wrote on 2021-06-27, 15:05:
You mean like the double sets of CPU tray I ordered twice the same evening without realizing it? 😉
Reply 39623 of 57297, by BitWrangler
Sent payment for this bunch, fingers crossed it gets here before I assplode with anticipation...
So 2 slotkets, 2 tualatin socket adapters, a 1.1A, a 733 cumine celly under the sink, plus sink. Got one of the V1.1 MSIs already, I want to start with a pair of identical slotkets... (Bet you can guess where that's going) Now I probably wouldn't be on that track, but I have a P2B-D that I got back in the day, and two 1.1GHz P3s
Sellers pic.
(Edit: I'm a dirty rotten liar, I have 1.0 Ghz even P3s, derp.)
(Edit2: I has tracking, yiss.)
Reply 39624 of 57297, by bjwil1991
Won a custom painted Mario NES-001 front loader shell for my one NES that has a broken shell (door won't stay closed, plastic is breaking off, and a few other things).
Seller's photo:
The attachment $_3.jpeg is no longer available
Reply 39625 of 57297, by Nexxen
SCSI PCI adapter,
Tekram DC-395UW Rev 1.01
(dc-395)
Attached are disk 1 and 2
Disk 1 has drivers and bios + utilities for Ms-Dos, Windows 95/98/2k/NT 3.51 + 4.x, OS/2 and Novell
From readme:
This driver diskette contains driver directories for DOS, Windows 95 & 98
Windows NT, Windows 2000, OS/2, and NetWare for the following adapters :
- DC-315U: max 20MB/sec 8-Bit Ultra SCSI
- DC-395U: max 20MB/sec 8-Bit Ultra SCSI
- DC-395UW: max 40MB/sec 16-Bit Ultra Wide SCSI
- DC-395F: max 40MB/sec 16-Bit Ultra Wide SCSI
* In this diskette *
* This readme file provides information for: *
* 1. files under the <DOS> : DOS ASPI Drivers & Tools *
* 2. files under the <NETWARE> : NetWare 3.1x/SFT-III/4.0x/4.1x/5.x *
* 3. files under the <OS2> : OS/2 v2.0/2.1/2.11/WARP 3.0 & 4.0 *
* 4. files under the <WINNT\3_51-4_x>: Windows NT 3.51/4.x *
* 5. files under the <WIN95_98> : Windows 95 (OSR2) & Windows 98 *
* 6. files under the <WIN2000> : Windows 2000 Beta x *
* 7. files under the <BIOS> : Flash ROM utility *
Disk 2 is an iamge of the SCO open server 5 disk (I can't mount it)
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 39626 of 57297, by Miphee
A lot of 478 CPUs WITHOUT bent pins. Miracles do happen!
Reply 39627 of 57297, by mothergoose729
bjwil1991 wrote on 2021-06-28, 03:55:
Seller's photo:
That looks great!
Reply 39628 of 57297, by vad4r
The attachment Sidewinder Force Feedback Wheel (1).jpg is no longer available
vae victis!
Reply 39629 of 57297, by Nexxen
vad4r wrote on 2021-06-28, 19:24:
WOW!
Reply 39630 of 57297, by bjwil1991
Another custom NES shell: TMNT, some long screws (1 is missing a long screw for the cartridge slot in one of the consoles), and 3 refurbished 72 pin connectors.
The attachment $_3 (1).jpeg is no longer available
The attachment $_2.jpeg is no longer available
Reply 39631 of 57297, by chrismeyer6
That Mario and TMNT NES shells are swesome
Reply 39632 of 57297, by bjwil1991
Definitely. Going to order SMB2, Lost Worlds, SMB3, TMNT1, 2 and 3 sometime soon.
Reply 39633 of 57297, by Bancho
Just won a Sony Vaio PCG-F801 Laptop.
Looks to be a cool little laptop, 12.1" 800x600 Display, K6 2+ 533 CPU. I think it has some sort of Trident VGA chip and not sure on the exact sound chip, but from my quick search is SB Compatible.
Reply 39634 of 57297, by Bancho
bjwil1991 wrote on 2021-06-29, 03:12:
Balloon Fight and Kirby's Adventure are two of my fav's
Reply 39635 of 57297, by BitWrangler
I am weak, saw these at $20 a pop and was gonna order 2, then I saw they did TV out also and ordered 3...
https://www.ebay.ca/itm/324276601358?epid=73839076
Reply 39636 of 57297, by Joakim
Almost bought a Vic 20 but I resisted it's really too old for my taste but it seems awesome when the 80 bit guy shows it off..
Instead I picked up this for 10 $.
The attachment IMG_20210629_163842.jpg is no longer available
A cooler master case and a working ( by me tested ) PSU, a GeForce 7 (probably defective) a HDD and a defective Asus m2v. In fact it was tampered with. A SATA data cable was connected from the motherboard and back into an other slot, a laptop ram was inserted in a slot (!) and two SATA power cables were forced into an IDE connector... I have no way of checking if the processor is ok. It does not even post, power supply doesn't start, probably a short somewhere it looks physically ok though but I don't care too much. I wanted the case.
Reply 39637 of 57297, by pentiumspeed
Picked up a beat up but to try out: Samsung SyncMaster 213T, Looks like same specs as 214T but panel is different.
Only 7 cdn dollars from value village.
Cheers,
Great Northern aka Canada.
Reply 39638 of 57297, by bjwil1991
Bancho wrote on 2021-06-29, 11:51:
My HP Pavilion N3350 has a K6-2+ 55oM, Trident i7 AGP, and ESS Maestro-3 audio. HDA 800x600 resolution (stretched and cannot stay unstretched after the system reboots).
Yours might have an ESS Maestro of some sort. Only 1 way to find out.
Reply 39639 of 57297, by Miphee
Yet another 771&775 CPU pack in average condition. Pinless CPUs are the only ones that survive the recycling center treatment.
