Reply 20 of 41, by Scythifuge
- Oldbie
I have to pop out the SD card and put it in my main PC to copy the texts, hehehe. It is up to 611k; getting there!
Config.sys:
SWITCHES=/FDOS=HIGH,UMBBUFFERS=10,0FILES=20LASTDRIVE=HFCBS=1,0STACKS=0,0DEVICE=C:\MSDOS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF /QDEVICE=C:\MSDOS\EMM386.EXE 16384 RAM I=B000-B7FF I=E000-E7FFDEVICEHIGH /L:1,11264 =C:\MSDOS\VIDE-CDD.SYS /D:CD-RW /D:DVD-ROMDEVICEHIGH /L:1,4560 =C:\WINDOWS\IFSHLP.SYSSHELL=C:\MSDOS\COMMAND.COM /E:512 /PSET PATH=C:\MSDOS;C:\WINDOWS;C:\SB16;..;SET TEMP=C:\TEMPSET TMP=C:\TEMP
Autoexec.bat:
SET COMSPEC=C:\MSDOS\COMMAND.COMSET BLASTER=A220 I5 D1 H5 P330 E620 T6SET MIDI=SYNTH:1 MAP:E MODE:0LH /S SMARTDRVLH C:\MSDOS\MSCDEX.EXE /D:DVD-ROM /E /M:12LH /S CTMOUSEC:\UNI\UNISOUNDPATH=C:\WINDOWS;C:\MSDOS;C:\SB16;%PATH%PROMPT $P$GCLS
Mem/p/c:
Modules using memory below 1Mb:Name Total = Conventional + Upper Memory-------- ---------------- ---------------- ----------------SYSTEM 11,824 (12K) 9,552 (9K) 2,272 (2K)HIMEM 1,152 (1K) 1,152 (1K) 0 (0K)EMM386 4,304 (4K) 4,304 (4K) 0 (0K)SMARTDRV 29,136 (28K) 12,736 (12K) 16,400 (16K)VIDE-CDD 5,008 (5K) 0 (0K) 5,008 (5K)IFSHLP 3,856 (4K) 0 (0K) 3,856 (4K)COMMAND 10,240 (10K) 0 (0K) 10,240 (10K)CTMOUSE 3,328 (3K) 0 (0K) 3,328 (3K)MSCDEX 16,144 (16K) 0 (0K) 16,144 (16K)FREE 660,944 (645K) 625,552 (611K) 35,392 (35K)Memory summary:Type of Memory Total = Used + Free---------------- ----------- ----------- -----------Conventional 655,360 29,808 625,552Upper 92,640 57,248 35,392Reserved 309,792 309,792 0Extended (XMS) 535,813,120 3,211,264 532,601,856---------------- ----------- ----------- -----------Total memory 536,870,912 3,608,112 533,262,800Total under 1Mb 748,000 87,056 660,944Total Expanded (EMS) 17,170,432 (16,768K)Free Expanded (EMS) 16,744,448 (16,352K)Total Extended (XMS) 535,813,120 (523,255K)Free Extended (XMS) 532,601,856 (520,119K)Largest executable program size 625,456 (611K)Largest free upper memory block 16,608 (16K)Available space in High Memory Area 2,288 (2K)MS-DOS is resident in the high memory area.
