First post, by RyanYTH
Hi folks, looking for some help here.
My DOSBox version is 0.74-3
If i set my registry this way, SDL_AUDIODRIVER to "dsound" my DosBox will have sound and music.
But if it is set this way, certain indie games (Eg: Dune Legacy, Eduke32) will not have sound.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment\
SDL_AUDIODRIVER value = dsound
However, if I change dsound to directsound in the same Registry, those games will have sound,
but DosBox will have no sound.
SDL_AUDIODRIVER value = directsound
Is there a value I can set or a dll i can download or something i can do, so that BOTH Dosbox and those games can have sound?
Appreciate any help on this. Thanks!
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
you can use a bat file that sets the variable and starts dosbox
Water flows down the stream
Reply 2 of 5, by RyanYTH
Qbix wrote on 2021-07-06, 07:24:
Thanks for the reply! But erm... sorry i'm not very familiar with batch file commands to run windows registry values. 😅
Are you able to type out the command that can set this? Thanks again!
Also, i'm running REMOVED together with GOG's dosbox. (REMOVED also uses Dosbox)
I'll need 2 seperate batch files to do this right? Thank you.
Reply 3 of 5, by Falcosoft
RyanYTH wrote on 2021-07-06, 07:28:
Thanks for the reply! But erm... sorry i'm not very familiar with batch file commands to run windows registry values. ^_^; Are y […]
Also, i'm running REMOVED together with GOG's dosbox. ( REMOVED also uses Dosbox)
And what happens if you simply remove that registry key completely?
SDL 1.2 should use 'dsound' and SDL 2.0 should use 'directsound' by default without explicit registry keys/ environment variables.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 4 of 5, by RyanYTH
Falcosoft wrote on 2021-07-06, 07:52:
SDL 1.x should use 'dsound' and SDL 2.x 'directsound' by default without explicit registry keys/ environment variables.
Update: It works! Now i have sound on BOTH those games and Dosbox!!
Thanks very much Falcosoft, thanks for your reply too Qbix! 😁
That is ... a great idea! Didn't thought of removing it as I'm afraid i might break something. 😅
Let me give it a try. Thanks!
Reply 5 of 5, by Falcosoft
RyanYTH wrote on 2021-07-06, 07:55:
Update: It works! Now i have sound on BOTH those games and Dosbox!! Thanks very much Falcosoft, thanks for your reply too Qbix! […]
BTW it was a rather stupid idea from SDL 2 developers to re-use the same environment variables SDL 1 used for completely different set of values. What's more some of these different values actually mean the same ( dsound/directsound)...
Website, Youtube
