First post, by butjer1010
Hi, i searched web for few days, and i had found many pages with BIOS for PKM-0038S, but i'm not sure which BIOS will "fit" to my MBO. I bought this MBO without BIOS chip, and now i wanted to try my luck with it. I have found BIOS for v3, v6, v2-2, but i'm not sure which from them will work on mine board. Every picture i found is slightly different from mine, and i didn't find E-2 version. Can anybody help me? I will upload pic of MBO in attachments.
    1.71 MiB
Reply 1 of 11, by Horun
According to the old website: http://web.archive.org/web/19980123080907/htt … com.hk/bios.htm
I think you want 4WSPD306.BIN BIOS Version 3.06 for PKM-0038S E-2A. That should be as close as you can get if you can find it.
Reply 2 of 11, by Deksor
We have a bios here https://theretroweb.com/motherboards/s/dtk-pkm-0038s
Reply 3 of 11, by butjer1010
Horun wrote on 2021-07-01, 19:19:
I already tried to download this bios, but it says that is not archived. Thanks anyway.
Reply 4 of 11, by butjer1010
Deksor wrote on 2021-07-01, 19:19:
That was the file i downloaded first, but my worry about this is that mine mbo looks different than this one on picture. Thanks
Reply 5 of 11, by Deksor
It should be fine. Back then you could even run a BIOS from another motherboard and have a chance that it'd work just right. Just try it and the worst you might get is a black screen.
Reply 6 of 11, by butjer1010
Deksor wrote on 2021-07-01, 21:23:
Thaks, i will try...
Reply 7 of 11, by butjer1010
Can You download this file? If You can, can You upload it for me?
Thanks in advance
Reply 8 of 11, by Horun
butjer1010 wrote on 2021-07-09, 11:28:
Thanks in advance
Would if I could but cannot DL it from the archive and cannot find it anywhere else yet. If I find it will attach it here....
Reply 9 of 11, by butjer1010
Horun wrote on 2021-07-09, 23:33:
Thanks in advance
Thanks in advance.
Reply 10 of 11, by Chkcpu
I realize that this topic is over a year old, but I just noticed this request for the 4WSPG306.BIN BIOS file (I assume 4WSPD306.BIN was a typo).
I have this file and share it here for anyone who needs this latest Version 3.06 BIOS for the DTK PKM-0038S / Gemlight GMB-486SG boards.
4WSPG306.BIN details:
Award v4.50G, 64KB
BIOS-ID: 11/28/95-SIS-85C471B/E/G-2C4I9G30-00
BIOS Ver.: 40-0306-2C4I9G30-V3.06
This BIOS supports all 486 CPU models, including the Am5x86-P75 in 4x33 and L1 cache WB mode.
It is free from the Y2094 and 2GB HDD display limit bugs, so it correctly supports drives up to 8GB.
Note that this BIOS shows the “L1 cache: WB/WT” option in the BIOS Setup only for the P24T and for Cyrix CPUs.
For the P24D (486DX2WB), Am486DX4WB and Am5x86, this 11/28/95 BIOS can detect if these CPUs are in WB mode and programs the chipset registers accordingly. It then hides the “L1 cache: WB/WT” option, because user interaction for this automatic function is not required.
So, you only have to find the correct jumpers for L1 WB mode for these CPUs and the BIOS takes care of the rest. 😉
Cheers, Jan
    4wspg306.ZIP
    45.18 KiB
    41 downloads
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 11 of 11, by butjer1010
Chkcpu wrote on 2022-10-29, 14:10:
I realize that this topic is over a year old, but I just noticed this request for the 4WSPG306.BIN BIOS file (I assume 4WSPD306. […]
Award v4.50G, 64KB
Cheers, Jan
Thanks man,
i have downloaded the file, for the future. I recently sold that board, but if i ever get board like that one, i will be ready 😀
