Reply 60 of 200, by Joakim
- Oldbie
After trying the computer for a while I must say it is a very good retro computer. The sound card is very compatible and in my case everything works, floppy, cd and even the battery.
There are a few downsides, the thickness and weight is one I guess but it's fine. The screen could have been lower native Res maybe. I doubt this computer will run any action game in native 1024x768 so everything will get scaled. Scaling looks good to me though and you can ofc run an external monitor.
In my sample, the computer has a major problem with static. It is extremely loud when I connect my Sennheiser headphones but also clearly noticeable with inbuilt speakers. All laptops I have used have this issue but this is quite extreme. I'm not sure if this is normal or if it is something wrong with it.
Edit repeated myself.
