Reply 19460 of 30558, by Caluser2000
- l33t
Caluser2000 wrote on 2021-07-15, 06:23:Fantastic progress today. […]
BitWrangler wrote on 2021-07-15, 02:41:Caluser2000 wrote on 2021-07-14, 23:51:Because the mobo on my first full Linux box has turned up it toes I've decided to repurpose it's chassis. Did all the component location and figure out what needs a bit of a trim up for the PGA370 mobo and 155 watt psu has to go last night while whatching the telly. This morning it was straight in to cut n tuck mode with the Fuller rotery grinder. I've never done anything this drastic before but it has be terrific fun.
The mod is coming along very well:
Ah took me a moment, forgot images post in reverse, thought you went from neat machine to chaos, now I see pic 2 is measuring up, and pic 1 is fairly neat result.
Been a while since I did similar. "Back in the day" for values of "the day" between about 23 and 19 years ago, the city where I'd turned up, seemed to be living in the relative stone age, as regards penetration of personal computers of any description, at least judging by what was available used. Now I'd got some decent boards but nothing to put them in. I carved up an innocent little NEC powermate 386sx, almost got a board in that, didn't finish the project and it was sitting open for a time, just using the base as it were. Then later I found an AT desktop case with PSU mounted flat and high, so there was room under it to carve out space for an ATX backplate, so that was the machine I had a K6-2 and Voodoo 3 in for quite a while. Cooling in it wasn't exactly optimal though. Probably I still have most of the parts of that powermate come to think of it, but I doubt it will go back together right after I hacked chunks out of it.
Optical drive/ffdd cage trimmed up and mounted. Hdd cage trimmed and secured. PSU has had its' original fan removed to reduce thepsu housing height by 12mm. Altered the psu housing to put a slightily smaller fan from a slot 1 cpu unit. Also added another fan to the back, now right hand side, grill.
Things to do:
Mark out then drill holes for mobo stand offs and attach them.
Lengthen the psu loom and attach to power output socket to the rear of the systems chassis.
Put a fuse holder in the psu for easy fuse fitment/removal.
Put more ventilation holes in the psu housing and system chassis.
And a few minor things to tidy the rear end up.
Need see if I can locate a pci 90 degree riser for the peripherals. Failing that use peripheral blanks to make smaller plates to mount small form factor goodies fitted to the pci slots as is. Manufacture a mounting cage for those if needed.Take care all...😉
Goodness I forgot the pics:
