Reply 20 of 34, by Matth79
Currently looking at a similar choice issue - on a P133
Choices being - for a DOS + Win98 setup
1. The built-in S3 Trio 64 (no 3D but good DOS compatibility)
2. Matrox millennium 2 - not sure how far it goes in D3D, but wouldn't run what I wanted in 98
3. S3 Savage 4 - the card I was going to use, but thought it had died (actually just didn't agree with the monitor) - DX6 capable I believe, and I think it did run "Got some Balls"
4. Geforce FX5200 (Quadro NVS280) - DX9 but weak
So interested in the "best drivers" issue, as I'd usually plump for the latest available
Reply 21 of 34, by swaaye
A P133 is quite slow for any 3D accelerated games so I would only look at things from a DOS and Windows 2D standpoint. Any of those cards will be solid for that. The Trio 64 is typical of what you'd see with a P133 and it would bring excellent compatibility. The other cards have more speed potential but the P133 is the bottleneck. A P133 is really at best a 640x480 DOS / Windows game CPU.
Reply 22 of 34, by swaaye
ReadySelectStart wrote on 2021-07-15, 22:24:
Sorry to spam, just an update in case anyone stumbles upon this: 61.76 was the issue for the corruption and glitching in 3DMark9 […]
Sorry to spam, just an update in case anyone stumbles upon this: 61.76 was the issue for the corruption and glitching in 3DMark99. 56.64 ran super smooth with no issues.
Scores now are:
3DMARK99: 4811 / 12087
3DMARK2001: 4353
I did occasionally hear the fan on the card ramp up and down so new thermal paste and general tlc is probably needed too.
In terms of using a driver such as 45.23, will this be stable especially with this card having 256MB of RAM rather than the 5200's 128MB?
When I did this hack on the 5700 either making it the 5200 or 5900, the system was unstable and there was corruption and glitches everywhere even on the desktop. Though the 5700LE apparently is an outlier in the line up and should be avoided it seems
You should let us know if it works. 😉 256MB cards do work with 45.23. You could also try 43.45 or 44.03.
Don't get too obsessed with 3DMark scores. NVidia was "optimizing" their drivers like crazy in those days to get more speed by reducing image quality and detecting popular software (ie 3DMark).
I would only consider newer drivers if you want to play a game that is newer than the 4x.xx series. 45.23 is from March 2003. Another reason could be something like the excellent Zeckensack Glide wrapper which was updated through 2005 and might benefit from a newer driver. GeForce FX is a nice match for that wrapper by the way thanks to their hardware support for palettized textures.
Reply 23 of 34, by RandomStranger
Joseph_Joestar wrote on 2021-07-12, 12:32:
The MX460 is a perfectly fine card for Win9x gaming. This includes most 2001 games, unless you want to play them at resolutions above 1280x1024 with AA and AF fully maxed out.
I'm not sure if the 5200 would be faster than the MX460. Maybe if it's the 128-bit version? In any case, both the MX460 and the 5200 will work with 45.23 drivers.
The MX460 is really one of the best budget option. The FX5200 is definitely slower with less stable frame rate. Even if it's the 128bit version in my experience. Maybe if it has decent memory clocks AND 128bit, but I couldn't test a version like that yet.
Reply 24 of 34, by ReadySelectStart
swaaye wrote on 2021-07-16, 05:29:
You should let us know if it works. ;) 256MB cards do work with 45.23. You could also try 43.45 or 44.03. […]
Scores now are:
3DMARK2001: 4353
I tried it with 45.23 and seems to have taken without issue.
The results:
56.64:
3DMARK99: 4811
3DMARK2001: 4353
Quake 3: 95.1
45.23 selecting FX5200:
3DMARK99: 5462
3DMARK2001: 4347
Quake 3: 94.8
I'll have to try running more benchmarks to see the difference more.
Reply 25 of 34, by AlexZ
Matth79 wrote on 2021-07-16, 00:45:
Currently looking at a similar choice issue - on a P133 Choices being - for a DOS + Win98 setup 1. The built-in S3 Trio 64 (no 3 […]
I would pick Savage 4 out of curiosity. Geforce FX5200 makes sense for Pentium II or III. Savage 4 was supposed to have usable 3D performance unlike Trio 64 or Virge DX/2. You should get the same compatibility in DOS as with Trio 64.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 26 of 34, by ReadySelectStart
Okay, I performed some more benchmarks. I also added more RAM as someone suggested and took note to see how that impacted performance. Not the most comprehensive benchmarking but hopefully gives an idea:
FX5500, 128MB RAM, 61.76:
3DBench 1.0c - 306.1
Chris' 3D Bench (640x480) - 138.9
PC Player (640x480) - 31.1
Doom - 111.97
Quake (360x480) - 58.7
Quake (640x480) - 51.1
Quake III Timedemo - 95.1
3DMark99 - 4790
3DMark01 - 4326
FX5500 as 5200, 128MB RAM, 45.23:
3DBench 1.0c - 297.9
Chris' 3D Bench (640x480) - Failed
PC Player (640x480) - 30.4
Doom - 110.47
Quake (360x480) - 57.6
Quake (640x480) - 21.2
Quake III Timedemo - 94.8
3DMark99 - 5462
3DMark01 - 4347
FX5500 as 5200, 640MB RAM, 45.23:
Doom - 108.08
Quake (360x480) - 57.3
Quake (640x480) - 20
Quake III Timedemo - 97.6
3DMark99 - 5956
3DMark01 - 4419
MX440, 128MB RAM, 45.23:
3DBench 1.0c - 190.3
PC Player (640x480) - 30.3
Doom - 70.5
Quake (360x480) - 47.4
Quake (640x480) - 30
Quake III Timedemo - 98.8
3DMark99 - 5183
3DMark01 - 2416
MX440, 640MB RAM, 45.23:
3DBench 1.0c - 415.9
Doom - 70.6
Quake (360x480) - 47.5
Quake III Timedemo - 101.8
3DMark99 - 6208
3DMark01 - 3051
MX460, 128MB RAM, 45.23:
PC Player (640x480) - 30.5
Doom - 108.08
Quake (360x480) - 57.2
Quake (640x480) - 20.1
Quake III Timedemo - 99.3
3DMark99 - 6540
3DMark01 - 3655
(Just to clarify, other than Quake III and 3DMark, the above was all done in a DOS boot not from command line/prompt in Windows)
Reply 27 of 34, by Putas
Some wild fluctuations in there.
Reply 28 of 34, by ReadySelectStart
Putas wrote on 2021-07-19, 12:16:
Especially with Quake at 640x480. I did not expect to see 20fps. Also surprised how much of a difference system RAM made to some of the tests
Reply 29 of 34, by Joseph_Joestar
Assuming you're running original Quake for DOS, and not WinQuake or GLQuake, you want to do the following to get proper benchmark results:
  1. Patch the game to v1.08
  2. Only benchmark under pure DOS i.e. not while Windows is running
  3. Benchmark only using standard resolutions such as 320x200 and 640x480
  4. Run FASTVID before performing the tests
  5. Disable VSync by editing Quake's config.cfg and setting these entries to zero:
    vid_wait "0"
    _vid_wait_override "0"
That should give you more consistent results. Also, don't use more than 512 MB RAM on Win98SE. It will cause all sorts of problems.
Reply 30 of 34, by ReadySelectStart
Joseph_Joestar wrote on 2021-07-19, 12:56:
Assuming you're running original Quake for DOS, and not WinQuake or GLQuake, you want to do the following to get proper benchmar […]
    vid_wait "0"
I used Phil's Dosbench tool in DOS for the Quake benchmarks. I'll remove the 128MB stick of RAM and test again
Reply 31 of 34, by zyga64
As Joseph_Joestar said, tests from Phil's Dosbench should be started in plain DOS mode (not in Windows 9x DOS box). To get speed boost you should run FASTVID before.
Although windows video drivers are doing same/similiar thing as FASTVID, Windows itself can cause slowdowns.
Check if your VIA based motherboard have "4-way memory interleave" option in BIOS. It should be enabled.
If there is no such option in BIOS, feature may be enabled by default. You can check it in SiSoft Sandra.
If Sandra shows no interleave, you can use Via Interleave memory enabler.
You can achive quite a big speed boost (in Windows) this way.
Direct link: https://soggi.org/files/misc/tools/Memory-Int … Enabler_0.15.7z
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 32 of 34, by ReadySelectStart
zyga64 wrote on 2021-07-20, 05:57:
As Joseph_Joestar said, tests from Phil's Dosbench should be started in plain DOS mode (not in Windows 9x DOS box). To get speed […]
It was in pure DOS mode. I don't touch DOS under Windows if I can help it
Reply 33 of 34, by dormcat
Savage4 is just as compatible as Trio64 and faster in every way; I've been using a Savage4 Pro on my Pentium-MMX 233 for DOS, Windows 3.1 (yes it has dedicated Windows 3.1 drivers), and Windows 98SE.
On the other hand, very few 3D-accelerated games work under Pentium 133; the minimum system requirements usually want MMX 166 or faster CPU.
Reply 34 of 34, by Matth79
dormcat wrote on 2021-07-22, 20:42:
Leaning toward the Savage 4 - I have a recollection that it did run "I've got some balls" with my old Cyrix 6x86 - just trying to think if I have any better PCI only systems to put the FX5200 in apart from perhaps putting the S423 back together that I used as a case donor, Hmm, I like... needs some DDR - I don't like, must see what insane price that's going for
