PC Remake - Pentium III 450 + Matrox G400 16MB
First post, by rcarkk
The remake of my second PC. It was bought in late October 1999.
Not all the parts are the same, but the motherboard, CPU, graphics card and sound card are identical. Even the case configuration is identical.
This build is supposed to have the same hardware of the original build, so no fancy extra hardware.
The original build had 64MB of ram. In late 1999 128MB was starting to be the norm for decent spec systems. 64MB was to short for Quake3 in 32bit. I choose 256MB for this build, because 128MB is not enough for some 2001 games.
CPU - Intel Pentium III 450MHz
Motherboard - Legend QDI BrillianX 1S
RAM - 256MB 133MHz SDR SDRAM @ 100MHz CL2-2-2
Graphics - Matrox G400 Single Head 16MB SDRAM Rev.A
Sound card - Creative Sound Blaster PCI 128 CT4700
HDD - Seagate 20GB IDE ATA100 5400rpm
CD-ROM - Creative 52x
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
The K6-III build
Reply 2 of 22, by Doornkaat
Beautiful! Do you intend to add an intake fan?
Reply 3 of 22, by rcarkk
Thanks mate.
Not really. It´s supposed to operate without side panel and the holes are to small at the front to provide relevant airflow, not to mention the noise. I need to get modern low noise 80mm fans though for future projects
The K6-III build
Reply 4 of 22, by teclillass
A very nice cable management. I have seen several users of vogons who have magic in their hands. You are one of them.
Reply 6 of 22, by chinny22
Congratulations you've managed to stick to your original speck and resist not going down the "I'll just upgrade this" trap just about everyone does.
The use of Matrox and SB PCI128 make it a pretty unique build for this day and age.
Just checking you know about the 8MB waveset file right?
http://vogonsdrivers.com/getfile.php?fileid=1 … menustate=47,38
Reply 7 of 22, by Joseph_Joestar
That's some beautiful cable management. Kudos!
I question the use of a SB128 PCI as that's a pretty terrible sound card overall. A SBLive would be a much better and still period correct choice. However, if you chose the SB128 for purely nostalgic reasons (i.e. you had it back in the day) then it is understandable.
Reply 8 of 22, by rcarkk
chinny22 wrote on 2021-07-19, 15:18:
Congratulations you've managed to stick to your original speck and resist not going down the "I'll just upgrade this" trap just […]
Thank you. It´s easy to go that route. I was focused on the original specs in October 1999. I still have the original zip drive and HDD, but they are faulty. And the CD-ROM was a 20x Aopen that came from my first PC. The case is not the same, but similar with the PSU in front of the motherboard. I don´t think the PCI 128 is a bad card for Windows 98 gaming. This machine wont be used for DOS
The K6-III build
Reply 9 of 22, by rcarkk
Joseph_Joestar wrote on 2021-07-19, 15:43:
Thanks man. I wont´use it for DOS gaming, so no problems with the PCI 128. I find it fairly decent for W98 gaming.
The K6-III build
Reply 10 of 22, by Joseph_Joestar
rcarkk wrote on 2021-07-20, 10:36:
Other than the craptastic FM synth emulation and the bland General MIDI, the SB128 also uses software emulated EAX, unlike the SBLive which has proper hardware EAX support.
I used a SB128 PCI for 4 years back in the day. IMO, it doesn't sound nearly as good as a SBLive under Windows. It will also tax your CPU more heavily in EAX capable games, leading to reduced overall performance.
Reply 11 of 22, by rcarkk
Joseph_Joestar wrote on 2021-07-20, 10:48:
Well, it was the card i had in it. But i know the limitations of the card.
The K6-III build
Reply 12 of 22, by bloodem
Gorgeous case & cable management! Also... great looking monitor! Wish I had a CRT, but that's the only thing that I can't have (according to my wife 😁 ).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 13 of 22, by chinny22
I had the PCI64 onboard back in the day and didn't mind it. For Win9x gaming was big improvement over the SB16 I'd been using.
Even did a good job of playing C&C in pure dos against the 486.
It's nowhere in the same league as the Live of course but I'd still rate it higher then onboard AC97 type crap that was also out during the time
Reply 14 of 22, by mothergoose729
Those pictures are incredible. It's like a show piece. I have never seen cable management this good on a build from this period. It's a work of art. Well done!
Reply 15 of 22, by rcarkk
bloodem wrote on 2021-07-20, 15:04:
I tried my best and really love this case. My girlfriend knows i love flat apperture grille CRTs, so no problems there 😀
The K6-III build
Reply 16 of 22, by rcarkk
chinny22 wrote on 2021-07-20, 15:21:
It sounds good to me, even with quality headphones
The K6-III build
Reply 17 of 22, by rcarkk
mothergoose729 wrote on 2021-07-20, 15:23:
Thanks for the kind words mate. I try my best in every new build. This is my 4th build since September 2020 were i put my effort in the cable management.
The K6-III build
Reply 18 of 22, by Joseph_Joestar
rcarkk wrote on 2021-07-20, 14:57:
Makes sense. Like I said earlier, nostalgia trumps any other reason when it comes to retro gaming.
In my case, despite now having a Roland Sound Canvas, there are still some games where I use OPL3 for music, since I grew up with that and it's what I most fondly remember.
Reply 19 of 22, by rcarkk
Joseph_Joestar wrote on 2021-07-20, 16:17:
Nostalgia is the main reason why we collect and build old PCs 😀
The K6-III build
